Old 03-30-2005, 02:37 PM   #1
fatray
What rims fit 72 with 8 lugs
I recently traded a shotgun and a tec-22 for a 1972 GMC 2500 2 wheel drive with 8 lug wheels. It's in poor shape,the person I got it from had no money and when needed new tires went to the junk yard and pulled 4 rims/tires off a junked tow truck. I can not see the writing on sidewalls of tires. I had no real luck searching, it seems most have only 5 lugs.
What I want to know is, can I buy someones brand new tire/rim combo from a brand new truck that people are selling on eBay after they upgrade?
What size tires came on my truck?
fatray is offline   Reply With Quote
Old 03-30-2005, 02:59 PM   #2
busterwivell
Welcome to the board. Where are you located? I've got 4 8lug 16.5 wheels (aluminum) with 2 tires that are new, they came off my 71 1 ton, so I know they will fit.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-30-2005, 03:45 PM   #3
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Welcome from Northern California. The new Chevy 8 lugs will fit. I have a set on mine and I like em. some people don't. The offset is not the same and the wheel rides a lil closer inboard. Think it was Junkyard John that said "looks like a fat man on stilts". Still, it was hard to beat $400 for tires wheels and caps that were almost brand new. When these tires go I'm gonna try for larger width tires to try and make up for the off set. Here's a link to a similar thread with a pic of my truck in it. http://67-72chevytrucks.com/vboard/s....php3?t=129261
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 03-30-2005, 04:38 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Please don't quote me, but I have heard the newer 8 lug dodge rims fit as well. Best thing to do is, if you can, take the truck to a local yard. The one's around here will let you "try on" some rims as long as you do all the work. You can see if you like them and see how they fit.
Chickenwing....you have an awesome truck bro. Not only is it real sharp, it also looks bad-ass!! It's also painted in my fave color combo for these trucks! I have a crappy 67 I can trade ya for! j/k
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-30-2005, 05:48 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That was me that said fat man on stilts...but mine is the same way with later steel rims on it.
Dodge wheels up through the mid 90's will work...same with ford up to the early/mid 90's...not sure about newer...I know ford went to a flat lug nut so those ones won't work.
If you plan on doing soe real hauling with it, then don't get the dodge or ford wheels. You'll need GM wheels, or correctly fitting aftermarket rims. These are hub eccentric, which means the hub carrys the load, the lug nuts just retain the wheel to the hub. But if it is just a car with a bed, then that won't matter.
I would also stay aweay from anything 16.5 too onless you plan on big mudder tires. Street tires are mostly all 16 inch now, and you'll pay more for the 16.5 with less selection. 16.5 will only be on older stuff...I think GM phased them out in 80 or so...somewhere around there anyways.
Old 03-30-2005, 08:28 PM   #6
Maximum Overdrive
December 21, 2012
I have a 70 GMC 2500 and it came with 750x16x6 from the factory. Currently I have TOYO 245x75x16 on it now. Newer dodge should fit. I have a dodge rim and factory tire as a spare and it worked when I needed to use it before I just bought the new tires. I have also used f**d rims (up to mid 80's, wouldnt know about after that though) on these 3/4 trucks with no problems.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 03-31-2005, 12:03 AM   #7
mr402
When I switched mine over to 16" rims the guys at the tire shop told me that they saw a lot of bent Dodge rims. They only had a few GMs bend and rarely had a F%$d rim come in bent. Given that I looked for a set of F%$d rims and never looked back. They've been on the truck for quite a few years now with no problems. Yes, I've hauled some pretty heavy loads.
mr402 is offline   Reply With Quote
Old 03-31-2005, 11:29 AM   #8
chickenwing
Thanks for the props! There is NO crappy 67 p/u. I'll still keep mine though.
Old 03-31-2005, 04:22 PM   #9
special70gmc
special70gmc's Avatar
these weld typhoons i love em awsome quality
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 03-31-2005, 04:40 PM   #10
screamin_c102
screamin_c102's Avatar
Chickenwing, I don't see anything "off" abot that tire and wheel combo, It looks great on your rig. I wish I had two toned Screamin, It looks alot classier.
screamin_c102 is offline   Reply With Quote
Old 04-01-2005, 05:25 PM   #11
chickenwing
If ya saw a head on or rear facing pic it would be more obvious. Longhorn Man has a bit more drastic opinion of it than me. Still think that a bigger, fatter tire will make up for a lot. Won't know for 30 thousand miles or so.
Old 04-01-2005, 07:45 PM   #12
GMC AMI
GMC AMI's Avatar
I agree with the Longhorn man. The back needs a much wider tire to fill that space or spacers behind the wheeels to look correct. Very fine truck Chick!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 04-01-2005, 09:37 PM   #13
Longhorn Man
If it makes you feel better, I think about that conversation more and more...every time I look at my rig.
it bothers me less...but I think I'll still end up with some spacers in there or something.
Old 04-02-2005, 04:46 AM   #14
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
I run this stock looking Ford rims on my LONGHORN...............A little deeper than the Chevy ones.............. Besides they came with the set of tires when I bought them...........
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 04-02-2005, 12:04 PM   #15
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I went with the 16" Eagle's ,whatever you do take this as an oppertunity to go with 16" wheels and tires , The 16.5 and gettting pricey and harder to find .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
