Old 03-30-2005, 03:32 AM   #1
brad juan
73 caddy eldorado steering column swap, any one ever done one?
I have a 72 caddy Eldorado with a tilt and telescope column in it, has anyone ever looked at installing one of these in there truck?
1972 chevy C/10, with factory air, SWB, 350,700r4, lowered 3 and 5.
brad juan is offline   Reply With Quote
Old 03-30-2005, 01:13 PM   #2
shifty
Questionable
shifty's Avatar
*bump*
Sounds cool! The big question is: Will it work?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-30-2005, 02:03 PM   #3
busterwivell
Don't know.........currently hooking up a 65 Cad tilt/tele on my friend's 56 Chevy......seems to be ok for us.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-30-2005, 03:28 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
where the column mounts behind the cluster will need the small locating tab removed. then it will fit but looks funny with the empty space around the bottom. otherwise fits great.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 03-30-2005, 04:25 PM   #5
shifty
Questionable
shifty's Avatar
empty space? can't picture what you mean ...
Old 03-30-2005, 05:02 PM   #6
724wdcopper
graphic designer
724wdcopper's Avatar
i believe he is talking about the black boot that normally covers the column-to-dash gap not fitting anymore.
724wdcopper is offline   Reply With Quote
Old 03-30-2005, 05:15 PM   #7
shifty
Questionable
shifty's Avatar
I don't even think I have a black boot on my column.
Right about now, I'll do anything to get my steering wheel off my crotch while I'm driving.
Old 03-30-2005, 08:06 PM   #8
dmec
dmec's Avatar
i set 1 up for a cab i am working on. used late model cad that had floor shift for upper half. grafted on truck lower column and made it to truck length. bolt in deal. but like was mentioned here, your lower shift collar that has the lever will probably be a problem. with the floor shift model, i eliminated the lower bowl and the larger diameter housing with the tilt and turn lever is right against the instrument cluster. anything is possible if you are willing to do it. the stock column is too far in my face for my liking and it is hard to see the bottom gauges. this column colapses 2 inches and when all the way out is stock length. i accomplished the same thing on my truck by shortening a van column. the column was shortened 2 inches and the shaft shortened 4 1/4 inches. love it. just right.
dmec is offline   Reply With Quote
Old 03-30-2005, 08:13 PM   #9
724wdcopper
graphic designer
yeah you do. check out the red circled area, then compare it to the other pics in this thread
