03-30-2005, 05:20 PM | #1 |
Questionable
Replacement dash bulbs?
Where can I purchase replacement dash bulbs locally? Is that something any auto parts store will carry?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-30-2005, 05:30 PM | #2 |
They should. Mine are 194s.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
03-30-2005, 05:34 PM | #3 |
67-72 Addict!
Go with LED's. They are brighter and will last alot longer.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-30-2005, 05:41 PM | #4 |
its all about the +6 inches
wall mart will have them.
194 is what its supposed to have, 168 will be brighter. LEDs are even better, but not real cheap. |
03-30-2005, 05:43 PM | #5 | |
Where can I buy LED's ?
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
03-30-2005, 05:46 PM | #6 |
More Cowbell....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
03-30-2005, 07:11 PM | #7 | |
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
03-30-2005, 09:25 PM | #8 |
Questionable
Okay - here's one for you....
I didn't realize the bulbs popped out of the black housing. Went to the store and got the bulbs. I forget the number on them, but they work, so, whatever. I popped the bulb out of the plastic housing. I checked the two tabs on the black housing and bent them up a bit so they would make springier contact (most were almost flat). I popped them back in one by one. All of a sudden, half of the lights in my dash didn't work. The brake light that used to light on crank stopped working. My Generator light started working. The oil pressure light started working. One of the speedo lights stopped working.... All of the bulbs are good and non of the black plastic housings for the bulbs have problems. I blindly rubbed the ring that the two copper tabs on the light housing makes contacts on the printed circuit board and managed to get every single light working on my truck....except maybe one or two. My right blinker refuses to work - but it was working before this whole ordeal (my left wasn't, so I swapped them). Does anyone know what could be causing this? At least the dummy lights work, but I reallly want my blinker lights to work.
03-30-2005, 11:13 PM | #9 |
i did the same thing here a month ago. Come to find out my circuit board was burned in a few spots from my amp gage. I am guessing when i changed the bulbs out i didn't get the circuits back in the same position and ended up replacing the board itself bout $45 but all works fine now.
03-30-2005, 11:22 PM | #10 |
Got Light Emitting Diode?
i bought PIAA LED wedge bulbs for my dash. like 20 bucks for 2 or something like that. if i sell my truck those babys are commin out!
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
03-30-2005, 11:43 PM | #11 |
Registered Cruiser
I've had this problem before. The cause was not having all of the little black lamp holders turned all of the way in. I located the culprit by reaching under the dash with my panel lights on and fiddleing with them individually. If you're not careful the electrodes on the lamp holders could tear into the printed circuit so bending them might not be a good idea. They fit pretty tight when they are snapped in all the way. Good Luck.
Edit; I just went out and took a picture of mine with 194 bulbs in it. The inside of the housing is painted bright white.
I intend to live forever. So far, so good. Last edited by jhwkns; 03-31-2005 at 12:27 AM. |
03-31-2005, 12:55 AM | #12 |
Its Magically Delicious
Im using 168's instead of 194's ... 168's are 1/3 brighter
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
03-31-2005, 10:46 AM | #13 | |
03-31-2005, 10:52 AM | #14 | |
