All Go, No Show
What is this?
And what does it do? And do I need this?
This is a 67 283.
69 LWB Rebuilt 283, aluminum intake, edelbrock carb, Mild Melling Cam, HEI. |
Member #1049
That is part of the crankcase breather/PCV system which is not used after 1968... it is not needed if you plug the hole on the top of the block with a "freeze plug" and use a PCV system from a later small block that uses it through the valve covers. but if your valve covers do not have any holes you definately need it.
All Go, No Show
Thank you. I am running the newer style valve covers with PCV valve.
Member #1049
then just head down to your local auto parts store and pick up a metal freeze plug, put on some sealant and tapp it in the hole in the top of the block and remove the can in the valley
Member #1049
if you like, you can also remove the oil filler tube on the intake manifold and plug it too. If you leave it on be sure to have a solid cap on it and not a breather cap
![]() Join Date: Nov 2004
I learn something new everyday....
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
