Old 03-30-2005, 02:47 PM   #1
69sixpackbee
Are C-30 & C-20 Rear Leafs Interchangeable?
Will the 11,000#, 7-leaf springs from a C-30 bolt up to the hangers and shackles of a '72 C-20?
69sixpackbee is offline   Reply With Quote
Old 03-31-2005, 10:34 AM   #2
Rod
Hollander Interchange manual mentions both being the same size 2 1/2 inch by 26x26. Those two sizes being the 3/4 C20 version to the 11000 axle 1 ton version.
Make sure its a 11000 lbs 1 ton version as the 7500 lbs 1 ton version are 19 3/4 by 19 3/4 which is shorter.
The way it looks in the book is that 3/4 tons had either 5 or 6 leafs while 1 ton had 7.
On my own 1 ton I have a 8 in the main pack and 7 in the auxillary..15 total.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-31-2005, 05:07 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have some 71 C20 leaf springs in my garage that are not that wide, closer to 2" wide. I'll measure them to make sure.
Where's post #2?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-31-2005, 05:11 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Originally Posted by JIMs70GMC
Where's post #2?
PM for details
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-31-2005, 06:55 PM   #5
69sixpackbee
Mine are the 2" wide, 7-leaf versions. I do not have overloads but I do have the Ride-rite bags on the truck. I notice it is a little "wavy" at times with my camper on it. I do have brand new Rancho 9000's, sway bars and good heavy tires. I only need about 40 PSI in the bags to get the truck level with a full load. It is possible that I have a mismatched set of tires on it (BFG's in the front and Cooper's in the rear). I was just wondering if I would benefit by putting the C-30 springs on it. I would'nt have room for an overload pack and the bags because I would not be able to fit the bags atop the springs and into the bracket.
Old 03-31-2005, 09:39 PM   #6
BobS
BobS's Avatar
My 71 C30 springs are 2 1/2 inches wide by about 51 inches eye to eye. 6 leafs in the main pack and 1 auxilliary leaf. It's a Longhorn.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 03-31-2005, 10:01 PM   #7
Rod
six pack bee...your rear diff a eaton or dana? Not sure it makes a difference but thought I'd ask.
Old 03-31-2005, 10:03 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'll add the leafs I have were with a dana 60.
Old 04-01-2005, 12:33 AM   #9
69sixpackbee
I have the Dana 60 rear.
