Old 03-31-2005, 11:02 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Water in TH350
Someone gave a TH350 that was supposed to be good. I put it into my '67 stepside and started the engine but did not drive it. I went to service the tranny and found lots of water in the tranny fluid. I think maybe the tranny and sat in the rain and filled with some water. I removed the pan and am draining it. I think I will just fill it with good fluid, change the filter and have another go at it. Check it before I drive it and see if it is clear...maybe change it a couple more times until clear. Any other thoughts?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-31-2005, 11:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
cross your fingers.
Old 04-01-2005, 12:33 AM   #3
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
No tranny fluid in the radiator? You prolly checked that already.
67 short step
71 Custom
MARIOS68PANEL is offline   Reply With Quote
Old 04-01-2005, 12:48 AM   #4
stllookn
stllookn's Avatar
Andy...thanks! I have two other trannys so it is only a matter of time and the PIA factor to change it out for a working unit...but I hate going backwards.
Mario...air/oil tranny cooler but this tranny might have been on a rad before and that may be where the water came from.
I don't know how much damage water can do to the clutch discs is my main concern.
Old 04-01-2005, 12:50 AM   #5
da-burb
"Ochre Ogre"
da-burb's Avatar
The best way might be a power flush. The poor mans way is to buy several cases of tranny fluid, remove the top cooling line at the radiator and run a hose to a large bucket. Pour the tranny fluid in while the engine is running. You will pump out the bad water/transfluid mixture. Then change the filter and you should be good to go. I had to do this last year because the radiator had a hole in the trans cooler. The water went into the trans and turned everything foamy Pepto-abismal pink.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 04-01-2005, 12:53 AM   #6
COBALT
COBALT's Avatar
As long as you don't have rust in there you should be ok...but if it sat for a while you're in for a big rebuild.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
