#26 |
Chinook Arch
I've got another vote for 275-60 15's on 8" rallys. Looks really good IMO. I think I'll look into 255's on front when these 235's wear out, but I've only got 500kms on them, so it could be a while
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus. Elsie's truck 2.5" dual exhaust with Hooker Aero Chambers Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350 ECE drop 3.5/5 |
#27 |
Until Seventy Times Seven
scoti-
Where on the LCA does your 18s rub? With the correct BS, I'm wondering if it's possible to tuck about an inch of tire at ride height. With a 3" dropped spindle and using a larger diameter wheel (larger outer loop), I thought it may clear the lip on the LCA. At full turn, I haven't yet checked the clearances on the LCA or other suspension pieces on how wide of a wheel I can run with a given BS. (I'm ignoring the inner fender issues for now.)
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#28 | |
