04-01-2005, 12:03 AM | #1 |
Need Build Date for 1972 St. Louis plant
Could some of you with an original 72 Chevy truck and with that build date label on the drivers door from the "St Louis plant" which is the 7th digit and coded "S" give me some info? I am trying to determine what month my truck was built if I were to have that label on the door.
The VIN would be like CCE142 "S" and then the next three numbers of the vin like "131"xxx. If someone has a "1972" truck with that GM door label and from the St. Louis plant, would you mind giving me the date on your label and those first three numbers so I can approximate a time frame for my truck build date? I know they can do this on tri five Chevy's but I have never seen a book on the 72 build numbers. Thanks Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
04-01-2005, 10:17 AM | #2 |
ttt
04-01-2005, 10:34 AM | #3 |
I will look for you. I have 2 72 chevy's that were produced in St. Louis. The one is CCS142S191899. I have the info for that one here in my office. I know without looking that that truck was built in 7-72. If I look at the engine and axle code it will narrow it to a few days. I thought that General Motors would send you the detailed info on when it was built to the day if you inquire tell them you have a clasic and would like that info I think they will oblige you. I will look at the other 72 chevy and ge back to you. I think it was built in April if I am not mistaken.
Tim |
04-01-2005, 11:59 PM | #4 |
Thanks Ozark Tim
I have located a source remaking the label and I need to get him a date pretty promptly so your help really is appreciated. Mine is back at S131510 but if a few guys post we can start identifying months to certain sequence and production numbers. Is the actual build date really supplied for your vehicle in those GM resto packets as I have never ordered one??? Mark
04-02-2005, 12:07 AM | #5 |
i have a 72 that was build there too.I will look sometime this weekend
04-02-2005, 07:49 AM | #6 |
its all about the +6 inches
The resto packet has no specifics on your vehicle, and I highly doubt they kept those records.
Tell me about the reproduction stickers....where, how much, is this a limited run? |
04-02-2005, 01:15 PM | #7 |
I checked all mine and no St Louis built ones.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
04-03-2005, 05:41 PM | #8 |
ttt
04-03-2005, 07:26 PM | #9 |
PROJECT 7DEUCE
I checked mine and they are fremont built unit's...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-03-2005, 07:38 PM | #10 |
my trucks build date is 9/71 and the numbers are 116
04-03-2005, 09:40 PM | #11 |
With this one at 116 on say late September 71 and maybe two months production and then your other one in July 72 at 191. Roughly say 7500 to 8000 a month would put mine with 131 at either 11/71 or 12/71. Thanks a lot Dean.
Mark
04-03-2005, 09:57 PM | #12 |
sorry those numbers were off the same truck
04-03-2005, 10:27 PM | #13 |
longhorn 71
My mistake Dean as ozark tim was the one getting his second 72 numbers. I used his first and yours and came up with that first rough figure. Thanks Mar
04-03-2005, 10:38 PM | #14 |
ok .I hope its information will help you.
