Old 04-03-2005, 06:17 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
What spark plug wires fit best with Headers & SBC
I think the Taylors with 135* angle look the most universal. ??
of course i know all headers are made slightly different and at first i am running a cheap set of Dynomax that I repainted. thanx , DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 04-03-2005, 06:36 PM   #2
Russell
Professional Grade
Russell's Avatar
I'd had no problems with just regular spark plug cables. Only one is a bit closer than I like, but if I went with any type of cable it'd have the same problem, the tube goes like right beside the plug, Its a tight squeeze getting a socket over the plug to take it out.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-03-2005, 06:41 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah, I have just regular spark plug wires and there is a couple that are tight but not to tight other then that no problems yet.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-03-2005, 08:33 PM   #4
crossy
crossy's Avatar
I'm not sweating the plugs too much I know how to get to them but i need some High perf wires. DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 04-03-2005, 09:49 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
I have used both the Taylor wires with 90 degree caps and MSD wires with the 90 degree caps. I use the ACCEL plugs, because they are shorter in the porcelein and this allows for more clearance around the #6 cylinder. I routed my wires along the side of the valve covers using a PROFORM wire loom and then had the wires drop down at each plug. It is clean simple and can be pulled easily to allow for plug replacement.
Old 04-03-2005, 11:08 PM   #6
crossy
crossy's Avatar
which of those proform looms did you use, thanx , DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 04-03-2005, 11:16 PM   #7
piecesparts
Go to Pace Performance ( www.paceparts.com ) and search for wire looms.The ones that I use are like the ones that have the Chevy emblem on them, but mine do not have emblems, just a polished aluminum finish.
Details
66261 - SBC Linear CHROME Wire Looms
PACE Price $45.12
Details
141638 - SBC Bow Tie Linear Wire Looms. fits 1986 and prior.
PACE Price $59.06
