67-72 vs.73-87 ways to tell chassis apart
if you look in the 4 x 4 post under rrrrrrrrrrrrrrrrrrr you will see i had a hard time of installing a new lift on my truck over the weekend. 67-72 front 4 x 4 leaf springs im told are 42'' (unloaded) and 73-87 are 47'' eye to eye. then he tells me that 67-72 rear u-bolts are square and 73-87 are rounded. (mine are round) so now im all messed up on what year truck i have. I have a 67 cab with a 70-72 front clip. is there a way on the frame to be sure of chassis year. i am going to drop some money in this truck and it would make for less headaches on the weekends and having to buy things twice while they hold my money
The Garage 1970 stepside 4 x 4 2005 caddy deville 1998 dodge 2500 diesel 2006 h-d street glide 1948 h-d rigid |
![]() Join Date: Sep 2003
someone correct me if I'm wrong, but I believe on the passenger side of the frame, right under the door, there are some numbers stamped on the frame. At least that is the way my '72 is. Perhaps those numbers could be used to tell what year the frame is. Maybe they have some correlation to the vin#?
#3 | |
you are correct, under my drivers door is a stamp 9/22/73
