04-04-2005, 12:22 PM | #1 |
It's Done When It Runs!!
Let the dumb questions begin :confused:
I need some help, and I know this is the place to come. I need to know what this is and where is it supposed to be mounted. Also, if this is some sort of ground could that be why my headlights don't work?
another: and one more dumb one. What is this? mounted on pass side inner fender, between battery and fender? Thanks in advance Jake
Or Give Me DEATH |
04-04-2005, 12:27 PM | #2 |
Resident Curmudgeon
1. Junction connector for main 12v feed off battery; RH Fender; No
2. Charcoal canister for gas vapors
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all Last edited by CPNE; 04-04-2005 at 12:28 PM. |
04-04-2005, 12:28 PM | #3 |
That's supposed to be bolted to the inside of your passenger side fender, just above and towards the cab from your battery.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
04-04-2005, 01:03 PM | #4 |
I'm watching you!
Heres a pic for #1.
The other I dunno, I donthave one. CPNE is most likely right. Hope this helps. Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold Last edited by 68haywagon; 04-04-2005 at 01:04 PM. |
04-05-2005, 03:37 AM | #5 |
Thanks for the responses. I'll get that bolted up right away. Now I just have to get back to the drawing board on why My headlights don't work. Thanks Again
Jake
Or Give Me DEATH |
04-05-2005, 07:59 AM | #6 |
blood type; Retumbo
in that first pic there is the black wire coming from the part in question. it has a "bell" on the end. this is a fuseholder. look for a similar wire near the batt at the end of the "gutter". it should be like a 20A fuse in there. IIRC this circuit feeds the headlight switch.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
04-05-2005, 09:00 AM | #7 | |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-05-2005, 09:13 AM | #8 |
I replaced the pass. side fender and radiator support on this truck and the headlights were working before that. I think I may have just left something disconnected or broke a fuse or something simple like that. I got the wiring schematics looking at them, so I should have this problem fixed in a couple of days. Hopefully, anyway.
Thanks again Jake
Or Give Me DEATH |
04-05-2005, 09:31 AM | #9 |
blood type; Retumbo
thanks for the correction CPNE
the fender & rad. support was removed? is there a ground wire disconnected?
04-05-2005, 12:39 PM | #10 |
MY EX DRIVES A BROOM
the ground for the headlights is near the voltage regulator on the drivers side, back side of the rad support, usually attached to one of its mounting screws....good luck
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
04-05-2005, 12:57 PM | #11 |
sounds like a ground then!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
