More trusty Less rusty
My daily driver died
![]() Last edited by rusted75 half ton; 04-02-2005 at 10:36 PM. |
ttt
to bad you arent near indiana, my 76 would be perfect for ya
how did your dd die? i used to live in lakewood by the way.
'67 c10 350/th350 |
Quote(how did your dd die?)Pretty much everything bad valve,thermostat broke,Brake m/c leaking ,an electrical problem,trans is not going into third and fluid smells burnt,haven't checked it out but a horrible screeching from the Drivers side wheel.I wouldn't mind fixing it all if I had something to work with,but every body panel has at least one rust hole and dent and a lot of bondo covered rust.I got alot of use out off it so I feel I should move on.
oh... well if i had something i'd hook you up. good luck. steve
'67 c10 350/th350 |
