04-03-2005, 11:22 AM | #1 |
205 front out put ??
my 205 has a 10 splined front yoke outout i want to turn it into one of the flange types. all of the flange type ones i can find seem to be fine splined. do they make a 10 spline flange style and does anyone have one. i want to use that style because i have a few of the cv flange driveshafts that i could use to save money.
thanks stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
04-03-2005, 12:35 PM | #2 |
horsepower junkie
your out of luck on that one....the only way to get flange front output is to change to a 30 spline or 32 spline output...its a relatively simple swap with the case in the truck....easier yet with the case out....heres a link to a place you can get new outputs and parts for a good price and good customer service...http://www.northwestfab.com/
67 short wide box,350/700r4/3.73posi 71 olds cutlass "S" mom bought new..12.30s@113MPH |
04-04-2005, 12:41 AM | #3 |
www.highangledriveline.com the best in the business, period.
04-05-2005, 07:21 PM | #4 |
i have a 205 in my garage that has the flange i need
its the 30 spline type shaft. it is for a manual tranny though. will that matter? how hard is it going to be to take the shaft out of that one and put in mine? it sounds like i could do it and not have to spend anything! which is exactly what im looking for. Know of any sites or a place where i can get directions?
thanks stan
04-06-2005, 12:03 AM | #5 |
horsepower junkie
yes you can swap the shafts...and you can do it with the case still in the truck..i havent personally done it..but a couple of buddys of mine have...they say it isnt really hard...if i was you ide take apart the one on the floor then youll know how it goes...
04-06-2005, 06:01 PM | #6 |
i did the one of the floor
i got it out. but needle bearing thing fell apart. there are tiny little pill like bearings everywhere in there. ill take the one out of my truck tomorow. but when i go to put the other one back in how do i get all them little bearings to stay in there?
stan
04-07-2005, 12:51 AM | #7 |
horsepower junkie
clean and dry them and pack them in with vaseline....that will hold them...
04-08-2005, 11:18 PM | #8 |
horsepower junkie
well did you win??? did it work???
04-09-2005, 12:59 PM | #9 |
i havent gotten to it yet
all i have done so far is get the shaft i need out of the parts case and got my truck into the garage. i dont think it will be much of a problem its actually not as complicated as i thought it was going to be. im going to take the whole transmission/tcase out and reseal around the adapter where it has been leaking. i also need to fix the speedo cable from leaking. ill take some pictures so that incase someone else is doing it it may help them.
thanks stan
