04-10-2005, 03:42 PM | #1 |
PROJECT 7DEUCE
a@n fitting's....
When you guys put a@n fuel line together wht do you use to join the pieces plumber's tape?anti siez? putting some new fuel line on the B.B. and need some advise..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-10-2005, 03:58 PM | #2 |
Bite me, import boy
If the fitting is going into a hole with pipe threads, then a small amount of sealant can be used on the threads. If you are talking about AN unions, or installing the fittings on the hose then you shouldn't need any sealant. I usually spray a little WD40 on the hose so that the fittings go into them easier.
Hope this answers your question
Jason '71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project "Facts are meaningless, You can use facts to prove anything that's even remotely true." |
04-10-2005, 04:07 PM | #3 |
PROJECT 7DEUCE
I replaced the steel fuel line in the pic with a earls adjustable unit and was wondering if I should use anything at the carb to fuel rail fitting's?? It also has a provision for a fuel pressure guage what should I use there..
04-10-2005, 04:11 PM | #4 |
PROJECT 7DEUCE
Whoops heres the pic..
04-10-2005, 05:44 PM | #5 |
member #16
If the new line has inverted flare like the one in pic it is metal to metal, no sealer needed, If the fuel ga. fitting is NPT use should use a sealer. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-10-2005, 06:01 PM | #6 |
PROJECT 7DEUCE
Thanks guys for the help....
