Will a 67-72 cab fit in the bed of a 71 Chevy long wide box??
Just what it says. I will be needing to take my cab across town and I just wanted to see if anyone had done this.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
Fits fine but sideways with the wheel tub fitting in the middle of the firewall.
Yup, it is a little tight though.
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside ![]() 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
I'm not all that concerned with the '71 that I'll be hauling it in....but I don't want to do any damage to the cab that'll be in the back. Will that be ok?
its all about the +6 inches
You can do it in a short wheel base too, but the tail gate will put a small dimple in the upper cab corner.
if you put some padding around the cab where it'll hit the bed, and go easy when dropping it in there, and drive around the potholes, you should be OK...but some small damage will be hard to avoid.
