Old 04-09-2005, 06:39 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
What size gauges are you using?
For those using Auto meter gauges- what sizes are you using in our factory bezels?.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 04-09-2005, 06:40 PM   #2
bjohn3x
2 5/8, 3 3/8 and 5"
1969 Chevy 1/2T SWB w/515HP 383, Viper 6 speed (.50 OVERDRIVE BABY!), 3.73 POSI rear
1965 Mustang w/367HP 289, 5 speed, 4.11 coming
bjohn3x is offline   Reply With Quote
Old 04-09-2005, 06:47 PM   #3
c10crazy
Like a Rock!
c10crazy's Avatar
bjohn3x- thanks, do you have any pics?
69 LWB
Old 04-11-2005, 09:49 AM   #4
Putter
More Cowbell....
Putter's Avatar
Here are the ones I am running.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-11-2005, 11:04 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Putter that looks awesome!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-11-2005, 11:06 AM   #6
Putter
More Cowbell....
Putter's Avatar
Thanks. I added them to the FAQ page that Ron started about mounting them behind the bezel.
Old 04-11-2005, 11:35 AM   #7
Yukon Jack
Yukon Jack's Avatar
c10crazy, I'm using the same size as listed by bigjohn3x.
Here is a pic
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-11-2005, 11:38 AM   #8
Mudder
Mudder's Avatar
Sames sizes mounted from the front.
Mudder is offline   Reply With Quote
Old 04-11-2005, 12:57 PM   #9
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
Mudder , Tyhat looks very sweet. Did you put that together? If so is the speedo accuate? Dig the fuel gauge in the middle .
67 short step
71 Custom
MARIOS68PANEL is offline   Reply With Quote
Old 04-11-2005, 02:02 PM   #10
'70_402
'70_402's Avatar
Heres Mine...
'70_402 is offline   Reply With Quote
Old 04-11-2005, 02:05 PM   #11
Mudder
Mudder's Avatar
The speedo is not accurate. At 50 mph on the speedo I am running about 60. You can change the speed gears in the transfer case to get it right. That gas guage is no longer available.
Old 04-11-2005, 02:08 PM   #12
Mudder
Mudder's Avatar
BTW........With the price of gas as it is, having the fuel in the middle like that is pretty depressing. Especially when you can see it moving down..........
Old 04-11-2005, 03:09 PM   #13
CHEVY & GMC FOREVER
Has anyone gone 160 MPH in your truck?
1985 Chevrolet C-30 454 1-TON Dooley
1969 CHEVROLET CST-10 PICK-UP
Good memories
1999 Chevrolet Z71 Ext. cab 5.7L
Good Memories
With a quart of oil, and a gallon of gas, she won't let no other car pass!!!.
& FOREVER
CHEVY & GMC FOREVER is offline   Reply With Quote
Old 04-11-2005, 03:26 PM   #14
Putter
More Cowbell....
Putter's Avatar
Only while calibrating my electric speedo. (during calibration, it runs to 160 while you drive to the beginning of your measured two-mile distance). Only actually ran about 45, though.!?!
Old 04-11-2005, 04:03 PM   #15
GMan69
GMan69's Avatar
WOW!!!
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 04-11-2005, 04:03 PM   #16
68haywagon
I'm watching you!
Putter how did you get the gauges to look like that. Are they mounted from behind?
All the guage setups look awesome.
Thanks,
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 04-11-2005, 04:19 PM   #17
Putter
More Cowbell....
Putter's Avatar
Yes, mounted from behind using the instructions from the FAQ page (but with a few of my own little tweeks). Also used a new bezel from Tim Christian. Went with the electric speedo, and the electric oil pressure. Super easy to calibrate the speedo, too. Requires a two mile stretch of road, a press of a button, and about 3 minutes of your time.
Old 04-11-2005, 04:46 PM   #18
68haywagon
I'm watching you!
FAQ section...got it. I always forget to look there.
Thanks,
Mike
Old 04-12-2005, 03:22 AM   #19
Mudder
Mudder's Avatar
Yes several times. I have a golf ball that I put under the petal. Keeps me down around the 75-80 mph range.
