Psalm 23
Front bumber mounts?
Could someone post some pics showing how their front bumber is mounted, I'd really appreciate it. Unless they are all mostly mounted the same I would need pics from a 71-72 GMC...my truck has the big 8 lug 3/4 ton axles but the cab is off a 71 C15.
At the moment my bumber is only mounted to the front of the chassis. I have 2, 2 foot metal braces that both have the ends bent at a 45 degree. I'm almost positive they go to the front bumber but I can't figure out how. Thanks
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy |
i am going to try and get pics now.....far as i know they all bolt up the same except for the 4wd's.......(someone care to help)?
Dan. 55 F100 panel truck project 64 ![]() 66 F100 302/C6/9" short fleet 67 IH 4x2 304/t984speed D44 373 locker lwb box 67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box 67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt 81 ![]() 83 ![]() 88 ![]() ![]() 96 Dodge 3500 CUMMINS/5speed/4x2 97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops ![]() ![]() ![]() ![]() ![]() |
heres your pics! this is on a 1/2ton 2wd...but they should be the same!.....
Psalm 23
Cool..I'll see if that lines up for me.
