Old 07-29-2002, 02:08 AM   #1
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
Reccomendations: cast iron oval port BB heads
Just like the subject says. i'm looking for real kick arse OVAL port cast iron heads, need iron becuase with what i'm gonna be doing it'll be too much for aluminum and the head gasket. I was thinking World Castings, but what about some factory GM stuff? thanks fellers.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 07-29-2002, 06:48 AM   #2
dwaite72lnghrn
I don't know what you are gonna do but if aluminum head won't hold up???? the oval heads won't either. If you are going for high rev engine I think you are going to need to go rectangular heads for higher volume. Remember aluminum heads were on the highest horse power 427's in the late 60's early 70's, and all high HP heads were rect. not oval because they can't flow enough volume. I would reconsider the oval iron They are good to about 3800 RPM. Rectangle are good up from there and I think most of the high HP were good to 6500 if built real tight.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 07-29-2002, 07:01 AM   #3
Big69C20 Toy
Livin' it up.
Aluminum wouldnt be good for the loading situation with turbos, the heads would expand and shrink quite a bit compared to the block, and with head gaskets being stationary i'd have issues.
I'm going oval because i want torque and i'm doing forced induction anyways, so it'll breathe i'll ram air down it's gullet.
-Greg;
Old 07-29-2002, 07:25 AM   #4
Big69C20 Toy
Livin' it up.
i forgot to mention i'll be using Propane as well so thats why the thermal expansion issues concern me.
-Greg;
Old 07-29-2002, 08:37 AM   #5
tom hand
CCRider
tom hand's Avatar
Turbo's with propane? Cool be sure to post a pic of that. Stock oval port heads should be fine. The rectangle port stock heads were overkill anyway, the ports were too big. Aluminum heads would work, but in the long term you will have less head gasket issues with, iron but that goes for any applacation with aluminum heads. If you don't retourqe them, you get to replace the gasket.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-29-2002, 09:48 AM   #6
Big69C20 Toy
Livin' it up.
Tom, you think i should just have my current ones ported a bit and such? it'd be nice not having to shell out the dough on new stuff.. any other opinions?
-Greg;
Old 07-29-2002, 10:21 AM   #7
junkyardjohn
junkyardjohn's Avatar
HEADS
3800 RPMS??? HMMMMM SEEMS KINDA FUNNY THAT I'VE BUILT SEVERAL SETS OF 049 HEADS THAT RUN 5500- 6000 AN AWFUL LOT ( I SHIFT IT AT 5200) ( MAYBE 3800 WAS A TYPO) RECTANGLE PORT HEADS DON;T PERFORM WELL FOR ME ON THE STREET. THEY TEND TO BOG AT OFF-IDLE (LIKE AT EVERY STOP SIGN) & STOCK TRUCK HEADS JUST HAVE ITTY BITTY VALVES IN THEM & ARE GOOD FOR LOW RPM TORQUE SITUATIONS ONLY. THIS IS NOT SOMETHING THAT I'VE READ ,OR HEARD ABOUT, BUT A RESULT OF MY EXPERIANCE, (SCHOOL OF HARD KNOCKS)
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-29-2002, 10:55 AM   #8
Pont
I need another Barley Pop
Pont's Avatar
Yes rectangular heads flow better but only at the very upper end of the RPM range. I also would question that 3800rpm figure on oval port heads. That figure should be close to 5000. I'm no expert on big blocks but I have read some books from big block guru's that say oval ports heads actually work better on application running less than 5500. If anyone is interested, I will look up those reasons and post them here. Also, GM made both an open and closed chamber oval port head. Do you know which way you wanna go regarding this? I'm running stock closed chamber heads on my 66 360hp/396 but I would think that you would want to run open chamber heads for your application.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 07-29-2002, 11:32 AM   #9
HuggerCST
HuggerCST's Avatar
I like 781's. Very good oval port castings. Especially with a little bowl work.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 07-29-2002, 12:42 PM   #10
Big69C20 Toy
Livin' it up.
i'd like any research i can get my hands on. from what i know/read the ovals are great for torque but cant keep up on the TOP end as in over 6500rpm, well this will be a low end motor, i'd use 6500 as top redline. I want to use Open chamber because it's better flame travel etc etc. and my CR will drop to about 8:1 or so.
-Greg;
Old 07-29-2002, 12:47 PM   #11
HuggerCST
HuggerCST's Avatar
781's are open chamber.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 07-29-2002, 02:05 PM   #12
67shortie
Green club
67shortie's Avatar
I run a set of 781's on my 427 chevelle with port work and 2.19 and 1.88 valves. I love em, with my 575 Ultradyne hydro cam they will blow the 295's off at at any speed in 1st gear=fun. With our heavy trucks, I would recomend nothing other. If you wanted to run a set of aftermarket ovals, world products "grumpy" series are hard to beat.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
