#1 | |||
Union Electrician
HELP!! with ignition
HI,
I have sbc 350 with hei ignition and keep burning up the hei module, ![]() ![]() ![]() I checked everything that I know how to check and nothing. I know someone on here has had this problem before ,so please whoever you are please help me out on this. Thank you in advance, Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
![]() Join Date: Feb 2000
How many volts are you getting to the HEI?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#3 | |||
Union Electrician
12.4 or 12.7 can't remember. Randy
How does it act when it goes out? Just quits running-will not start-sit awhile and then will restart?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#5 | ||||
Union Electrician
I had a similar problem once. The wire to the starter had come off, and when it would swing just right it would ground out and the truck would die for a second, when it ungrounded itself it would run just fine.
I would recommend checking all of the gounds. make sure the engine has a good ground to the frame too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#7 | |
#8 | ||||
Union Electrician
#9 | |
Here's what it looks like:
#11 | |||
Union Electrician
Thanks a bunch I'll look into this tomorrow. Randy
