Old 04-18-2005, 04:21 AM   #1
teamharvey
teamharvey's Avatar
Buckets finished
They were in much worse shape than I expected when the PO`s covers came off so I had to add a little here and there. Overall I am happy with the outcome. I highly recommend using cable ties in addition to "hog rings" as it really helps getting it tight.
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 04-18-2005, 04:32 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
VERY NICE! You make it look easy!
Keith
Convert to disc brakes.
Old 04-18-2005, 11:20 AM   #3
71RestoRod
71RestoRod's Avatar
Great job!
Absolutely awesome job on your seats.
I’m curious (just starting this job myself) if the replacement seat covers have stiff wire installed around the inserts, and if so, did you use the cable ties fastened to these wires to pull the upholstery back tightly into the foams? Did you re-use the wire ties that were originally used for this purpose?
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 04-18-2005, 11:53 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Wow, looks sharp. What color is your truck?
I saw them install seat covers on one of the auto shows on TV. They used silicone spray over the foam to help slide the cover's down over the backs. The front seats in my '72 don't have the original vinal pattern on them so I'd like to replace that this summer. Hopefully, I can do as good a job as you have.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-18-2005, 12:35 PM   #5
Yukon Jack
Yukon Jack's Avatar
Those look wonderful. Nice job!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-18-2005, 04:10 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-18-2005, 06:59 PM   #7
teamharvey
teamharvey's Avatar
The new covers did not have wires. They have an added strip of very strong material with a seam sewn through the middle of it that is used for the hog rings. I just puntured a small hole through the cover and material just above the seam for the cable ties and pulled it tight. It worked very well.
Bouncy, my blazer is red.
1 incredible wife
2 great kids
Old 04-18-2005, 09:39 PM   #8
orangeuavol
GO VOLS!
orangeuavol's Avatar
Great work! I'll need your address so I can send you my seats to do next
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
