Old 04-20-2005, 07:13 AM   #1
ss70l78
What's the difference?
What is the difference in using stock springs with lowering blocks in the back versus 3" drop springs in the back and should I use lowering shocks in either case? The front has drop spindles with stock springs.
ss70l78 is offline   Reply With Quote
Old 04-20-2005, 07:42 AM   #2
Your trailing arms will hang lower than the rear by the size of the block.You`ll retain stock ride(sort of),except by spacing axle closer to frame,you lose travel.The lower springs are designed to ride/travel at desired height while keeping close to stock ride.
