Old 04-20-2005, 09:50 AM   #1
72Custom/10
72Custom/10's Avatar
72 custom/10 5 speed conversion
i have a chance to buy a 5 speed transmission out of 80's V8 camaro. i would love the final gear ratio of that transmission to put in my Custom/10. it has a 350 with a 4bbl, intake, cam, and headers. i think the T5 transmission will give me much more speed and gas mileage. i'm wondering if the original 3 speed and the 5 speed are the same size. if anyone has already done this conversion, let me know how u did it and what it took to get it done please.
72Custom/10 is offline   Reply With Quote
Old 04-20-2005, 03:07 PM   #2
Aubigmac
I did this conversion on my 72 a few years ago. it bolts up fine. I believe I even used the same bellhousing.
The bigest problem was the clutch. The T5 input shaft splines are at the very tip of the shaft. None of the factory clutches would let the input slide through it far enough to engage the pilot bushing. I wound up having to have a custom clutch made that offset the splines towards the flywheel. Problem was the only pieces that would work were light duty car junk and I broke two clutches. Thing that killed the whole deal was when the transmission broke. I was very easy on this tranny the whole time I ran it cause I knew it wasn't made to hold up to a truck that heavy. When it broke I was just casually shifting from 1st to 2nd and it came apart.
Aubigmac is offline   Reply With Quote
Old 04-20-2005, 07:26 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yep, the T-5 is not a strong tranny. There's a reason they were never bolted to anything bigger than a 305.
There is tranny mount issues since the camaro one is mounted at an angle
Maybe shifter location problems
maybe speedo cable verses electric problems
Old 04-20-2005, 09:13 PM   #4
72Custom/10
what other 5 speeds were made to do this conversion?
Old 04-20-2005, 09:58 PM   #5
Longhorn Man
Full size pick ups...nv-something or another (nv3500 maybe?) Fairly strong tranny. i'm sure some one who knows that tranny will chime in, I don't know specifics, but there's a few ppl on here running them.
I just noticed that you just joined...
Welcome to the board from central ohio, where you located at in the world?
Old 04-20-2005, 10:14 PM   #6
72Custom/10
i'm in south carolina, dead center of the state
Old 04-20-2005, 10:21 PM   #7
72Custom/10
i've looked at an nv3500 on ebay before, the thing that discouraged me from it is the permanent bell housing. i was wondering if the linkage clutch that my truck has would work on the hydraulic clutch. i am assuming that the nv3500 is set up for a hydraulic clutch. this transmission came in the 80 and 90's 1500/2500's right?
Old 04-21-2005, 05:36 AM   #8
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
The NV 3500 and 4500 have removeable bellhousings. Will allow you to retain a mechanical type clutch linkage.
The 4500 is a heavy duty low geared transmission that was first available in early 90's Chev and Dodge pickups up until about 2000. There were 3 different ratio selections available.
The 3500/ 3550 has been available in several different vehicles from Dodge and Jeep (up to 1/2 ton Dodge Ram) since the late 90's. It is a close ratio 5 speed. It is rated for up to 7200 GVW and 300 lb/ft torque.
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
