Old 04-23-2005, 04:26 PM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
asap
I will be replaceing my Lock Cylinder today and I need to be sure that this (http://www.partsamerica.com/ProductD...pe=521&ptset=A http://www.partsamerica.com/ProductG...name=Lockworks ) will work. it says on the buyers guide (2nd one) that it will but I want to make sure. thank you for your fast replys! matt
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 04-23-2005, 04:35 PM   #2
1Ton
1Ton's Avatar
Looks like the right one to me.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 04-23-2005, 04:43 PM   #3
79gmcc15
79gmcc15's Avatar
do you know of any tips I should know befor I pull the wheel?
RIP ELJAY
Old 04-23-2005, 05:19 PM   #4
Russell
Professional Grade
Russell's Avatar
Just keep an eye on everything, and don't forget where stuff goes, hehe
Actually, removing the lock cylinder is a very easy procedure. Just make sure that you set yourself up with a good locking plate compressor, and wheel puller!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-24-2005, 01:05 AM   #5
1985K10
1985K10's Avatar
As Russell said, steering wheel puller and a lock plate compressor, they make life a lot easier!
The Lock cylinder is a really easy fix, theres one screw holding it, and i think it needs to be in either the unlocked or run position to be removed.
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
