33"s on a not lifted stepside -89 ?
Can i have 33"s on my stepside 1500 1989 its not lifted!!
do they rub? i have got 15x10" Shelby Slotmags
im from sweden and i have a Chevy 6-fot 4x4 8-lug -74 |
I have been told by shops that you need atleast 2 1/2" so they dont rub. Like a body lift of small suspension lift.
85 chevy K10 350 crate, headman headers, street avenger carb, accel distrib , rebuilt 700r4, on 33" Super Swamper TSL's, 4 inch Pro Comp lift, shocks, and steel braided brake lines. |
Chevys Kick A$$
I think they will rub, but not completely sure. I believe you would need to do some major fender hacking or get a small lift or body lift.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
![]() Join Date: Apr 2003
the height is ok, but the width will kill you, if they are 33 12.50's. They will rub when you turn, and bend the heck out of your chrome trim around your wheel openings. I ran 285's and 295's on my 89 4X4, and had little trouble. The 285's measure out as 33 X 11.0 inches.
Good luck David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
thanks for all posts!
how do i easy lift it? in the rear its just to put some metalblock between leaf and axle.. but in the front? maby 2" i dont wanna buy any kit. usa is so far away... /=
to fit 33 x 12.50s on 15x10s on a 88+ truck, and no lift kit, you have only one other choice. hack the fenders. you MIGHT be able to get away with a 33 x 10.50 on a 15 x 8 rim and the right backspacing, but its doubtful.
ok... crap.. i dont wanna lift it right now...
31x10,5 ? 32x10,5 ? do they fit? anyone know? would love to see some pics of stepsides with 31-33"s !
You could put 2" add a leafs in the front and rear springs, that would give you enough and they are only like $55 a set. Also, if youwent with 15x8's instaed of 10's they would fit much better and give even more clearance.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Uncle H. is this cartoon
89 trucks don't have front leaf springs without a solid axle conversion.
I hear people run 32x11.5's easily on unlifted trucks. BFG makes a 33x9.5"-15 in a/t and mud if you want the ground clearance. BTW You can fit a 33x10.5"-15 tire on a 15x7" wheel. That'd make it almost half an inch narrower than if mounted on a 15x8". Last edited by uncle_handsome; 04-14-2005 at 02:44 PM. |
this are the sizes i can choose from
http://www.hjulhandla.nu/4x416.htm http://www.hjulhandla.nu/4x4van.htm would really like to have 15x10" cuz the look soo cool ![]()
the 15 x 10s arent gonna cut it. that's where most of your problem lies. they're too wide.
Chevys Kick A$$
Yeah, I think those 15 x 10s are still going to be too wide.
-Later
If you want a fat tire look, BFG makes a 325/60R-15 in all-terrain and mud terrain that is 30.5" tall and almost 13" wide. That tire might fit on an unlifted truck since it's about the same diameter as a stock tire. (Since it's an unusual size it'll cost you a little more than a 33/12.5-15)
Other companies also make short, fat mud tires like 29x11.5, 30x12.5 etc. If you want to run the 15x10 wheels you'll need a shorter, fat tire. Last edited by uncle_handsome; 04-15-2005 at 10:03 PM. |
tried a 32x10,5-15 spare tire today and that was no problems...
but the rim was 15x8" tried the 10" rim on without the tires and it was 4" out from the fender.... maby 8" is enough i wanted 10" cuz i had a 75 blazer with 15x10s...but it seems the older ones have more space for wheels... posting pics on stepside with spare tire and blazer 75 with 15x10
#15 | |
You can crank your t-bars up to gain front height, or install the ford keys for a couple inches, then blocks or AAL in the rear or BL, but your not gonna fit 33's on an 89 without some kinda lift and still have the truck offroadable without trimming metal.
#16 |
33s will fit real easy with a 3" body lift, as for being "offroadable", until you put a straight axle in the front, its not going to be very offroadable anyways. IFS was designed with one thing in mind, and that is on road handling.
#17 |
ordered tires today..
31x10,5-15 i hope they are gonna fit on my 15x10 rims.. ![]()
#18 | |
i had the body lift in mind but its to much work at the moment..
im from sweden and i have a Chevy 6-fot 4x4 8-lug -74 Last edited by TheSwede; 04-19-2005 at 03:36 PM. |
#19 | |
#20 |
got the tires this weekend!! =)
looks like this! and it dosent rub!
