Old 04-17-2005, 02:22 PM   #1
jermasaurus
jermasaurus's Avatar
Camber Corecting Question
Hey, I have the DJM 3" drop spindles, and want to go lower in the front. I don't want to get the dropped control arms mainly because of the price.
I am wanting to get either 2" or 3" drop springs. So... I was wondering if anybody knew whether I would be able to correct the camber without having to make any modifications like extended control arms and things like that- if I were to do the springs.
jermasaurus is offline   Reply With Quote
Old 04-17-2005, 02:51 PM   #2
ocbaud
Garage Queen Material
if you put in new springs, just make sure you go get a good alignment afterwards. that should take care of most of the camber problems.
ocbaud is offline   Reply With Quote
Old 04-26-2005, 03:13 AM   #3
bluejimmy76
bluejimmy76's Avatar
i used a 2 1/2" spindle and cut a coil off my front spring on my truck. I know I could have gotten the alignment done right myself but I took it to a shop and the guy totally jacked it up. So I installed offset upper control arm shafts and did the alignment myself. It turned out killer, I don't have a ton of shims in there. Definitely corrects any camber/caster problems. The shafts are available thru Moog or TRW.
My 1st 76 sierra classic stepside
Owned:
76 chevy suburban
85 chevy K1500
90 chevy C1500
90 chevy K1500 sub
97 chevy C3500 crewcab dually
2000 chevy C3500 crewcab dually
bluejimmy76 is offline   Reply With Quote
Old 04-26-2005, 12:00 PM   #4
bodydropped
if u have spindles and do coils u wont have a camber problem im runnin coils and i have a camber issue so im goin to by spindles to fix the problem
bodydropped is offline   Reply With Quote
