04-22-2005, 02:14 AM | #1 |
86 s10 blazer keeps blowing ECM B fuse
Every once in a while when I start the Blazer I turn the key and it runs for about 2 seconds then dies, then will not start back up, due to the 10amp fuse marked ECM B. I also get no trouble code from the diagnostic mode.
This seems to happen randomly once a week or so out of nowhere. I have a 1986 2.8L V6 S10 Blazer. If anyone has any idea how i can narrow down the problem, there are tons of sensors and relays and crap. Could it be the oil pressure sensor? It also has TBI and a manual trans, 4x4. thanx |
04-24-2005, 12:35 PM | #2 |
You need a new fuel pump...Ecm b fuse is tied into the fuel pump relay circuit... That should do it...S-10 wiring are a little funny to fix...I have run into this before..I have 6 blazers here for parts..
04-24-2005, 06:02 PM | #3 |
wouldnt the thing not run right if it were the fuel pump though?
04-24-2005, 06:16 PM | #4 |
If you look at a wiring diagram,the ecm b fuse controls the fuel pump and the injectors. Thinking on it a while ,it may be in your distibutor too.. The fuel pump and pickup coil in the dist,wont set a code...Did you change the oil pressure switch?
Does your radio work fine? I know this sounds weird but check all the other fuses,if the radio fuse is blown too,change that fuse out.. It will backfeed into the ecn b fuse...Trying to help. Last edited by bisquik65; 04-24-2005 at 06:18 PM. |
04-25-2005, 02:16 AM | #5 |
my radio and stuff works fine. I am a little confused about the oil pressure switch, or where it is. On the drivers side of the block just under the oil filter there are 2 switches/sensors. One has 2 connection posts, the other has three. I assume one is the oil pressure swich, but witch one, and what is the other thing?, fuel pump/pressure regulator?
04-25-2005, 08:24 AM | #6 |
The 3 wire one is for the fuel pump. If your motor loses oil pressure it will shut the pump down,you may want to check oil pressure too.
04-26-2005, 02:37 PM | #7 |
it is the oil pressure switch, if i unplug it everything works fine, except for the gauge anyway....
04-26-2005, 03:47 PM | #8 |
OK glad you found it,Later,Erick
04-26-2005, 05:57 PM | #9 |
thanks for the help, if u are parting out some s10 blazers maybe i get some parts from ya....
04-26-2005, 06:31 PM | #10 |
Welcome to the board!!!Post your location so it will help you find stuff closer to you..
04-26-2005, 10:12 PM | #11 |
guess im kinda far here in Reno Nevada
