Old 04-22-2005, 01:48 PM   #1
Martin64
Martin64's Avatar
Rear End Question
Is there a way to tell what the gearing of a rear end is just by looking at the outside of it?
Here's the situation, one of my neighbors moved out and left a rear end in the car port. Management had it moved over to the dumpster, which just happens to be next to my garage, and low and behold it has 6 lugs and drum brakes. After closer inspection it has a "GM" casting on it in raised letters. So right away I figure it's a 6 lug GM rear end that, with just a little luck, may be the 3:08 that I'm looking for.
I've moved the rear end into my garage so I can figure it out.
There's also another way to tell but I forgot how. Something about turning the axle and counting the turns at the yoke and multiplying by some number.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 04-22-2005, 02:22 PM   #2
kaycee
kaycee's Avatar
Thumbs up
You might as well as pull the cover off and see what is stamped on the ring gear and devide them and that will give u your ratio.This is the only for sure way to tell allso u will see if it is full of metal shavings or not.Good find look and see if it has coil spring or leaf spring perches.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-22-2005, 03:39 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
There should be a ratio stamped on the ring gear, should say something like
"GM 41 10 4-72", with the 41 being the teeth on the ring gear, and the 10 being teeth on the pinion, working out to 41/10=4.10 ratio. Should also have a date code, 4-72 being April '72. I've been inside two 12-bolts and they both have this. Just spin the ring gear looking for the stampings, and if they aren't there count the teeth as menitoned above. Also check out the conditon of the gears as long as you are in there.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 04-22-2005, 04:20 PM   #4
69 Short Fleet
I'd pull the cover as mentioned to see whats in there, prolly a good idea to check the internals condition anyway.
69 Short Fleet is offline   Reply With Quote
Old 04-22-2005, 08:46 PM   #5
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
with some luck, you could figure out that he was saving it cause it was a posi unit
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 04-27-2005, 01:12 PM   #6
Martin64
Martin64's Avatar
Ok, it is a 4:10 and I'm not positive but it may be a posi. It has some extra looking hardware inside that I haven't seen before. If anyone wants this rear end, come and get it. If you're feeling gratuitus and want to swap me a 6 lug 3.08 rear end then I will gladly accept it. Otherwise it's yours for the taking. I got it for free and will gladly pass it along
The teeth on the ring gear looked alright. I did find a couple very small pieces of metal, about the size of #2 pencil lead that breaks off a pencil end when you press too hard while writing. Since it still has oil in it I just rolled it so I could get the cover off to count the ring gear. The rear end cover has been welded up. It looks like it may have came off a 4WD. It has leaf spring mounts on it.
Again If you want this rear end it is free for the taking. I'm picking up my new Harley-Davidson today and the rear end is taking up too much room in my garage.
Martin Gibson
USAF Retired
1964(-ish) C10
Old 04-27-2005, 06:58 PM   #7
68w/sbc406
68w/sbc406's Avatar
if you spin the part of the rear end that hooks to the drive line, how do the tires spin
Old 04-27-2005, 11:00 PM   #8
Martin64
Martin64's Avatar
I don't know. It doen't have brake hubs to see spinning and I couldn't see both axles at the same time and didn't have an assistant around to help me with that part. But I put it back outside...had to make room for my new Harley I picked up today.
Martin Gibson
USAF Retired
1964(-ish) C10
