04-29-2005, 08:47 PM | #1 |
Active Member
Front end rebuild
I know this isnt the suspention section , But I want to do my upper and lower control arms and I was hopeing you all could tell me the best place to get the stuff. I went to local auto zone , They have all the ball joints but they say the A arm shafts and bushings are not available. So where do I get the stuff cheap as possible. Thanks for any advice and help
67 short step 71 Custom |
04-29-2005, 10:59 PM | #2 |
Sanity is a state of mind
TTT
I'd like to know as well. I think you can even install later parts if you use the ball joints and all. I would also like to know where to get lowered spindles. Good luck Mario.....
67 K-10 8ft step 250/465/timken 4 shaft/373 to 1 70 C-10 Panel Vortec V/5spd BW od /307 to 1 70 C-30 9ft stepside dump 350/465/ posi and a few too many other trucks, cars, jeeps, cruisiers, and M/Cs ...o~`o |
04-29-2005, 11:40 PM | #3 |
Got Light Emitting Diode?
you can check with and of the vendors to the left side here http://67-72chevytrucks.com/index.html
but i got my stuff locally
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
04-29-2005, 11:56 PM | #4 |
I priced out ALL the parts you need to rebuild the front-end and found the cheapest price for Moog parts on www.summitracing.com. I did not bother to price out other manufacturers.
04-30-2005, 12:12 AM | #5 |
I was able to find the upper A arm shaft bushings at Pep Boys. Both autozone and Pep Boys had the upper ball joint I needed but Pep Boys was way more expensive. You need to check around.
Terry 1970 C20 Camper Special |
04-30-2005, 12:39 AM | #6 |
I ordered my entire front-end rebuild kit from Early Classic Enterprises - all Moog parts right to my door. Everything I needed minus new control arms. It was expensive, but I could call them during their business hours and they'd help me, and they knew what they were doing. They even sent me out replacements when it was obvious some of the stuff they sent me was wrong. Good service.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
04-30-2005, 12:44 AM | #7 |
Active Member
Thanks for the reply`s I will call around more tommarrow. I was hopeing the unavailable story I got from Auto Zone was just from them. I looked at a couple board vendors and they told me they cant compete with local parts stores on the a arm parts. I dont want to go with lowered spindles but I am going to put some lowered springs in and I figured while I`m in there I may as well do some real work on it .
04-30-2005, 12:48 AM | #8 |
Blue 67
You may want to check with Brothers too. They are having a spring sale which is suppose to last until may 31st.
04-30-2005, 06:13 AM | #9 |
I've bought all my front end parts from "PST". They have just about anything you need for the front end. They sell in kit form. Takes all the guess work out.......they've been in business for years and are at major auto swap meets.....
www.p-s-t.com
1997 GMC Sierra Ext 1965 Mustang |
04-30-2005, 09:07 AM | #10 |
Working on a Nova.
Remember this is the steering on your truck! Go with a good well respected name for the parts not generic. Moog and PST I know are good companies. I did a 66 impala with moog and it was a tight set. I did a 63 impala with PST nice parts but there instructions left alot to be desired, so I pulled out my old moog instructions from the 66 and it all came together just as good.
04-30-2005, 09:11 AM | #11 |
Howdy:
I have this very project in progress on my 2WD '67. Was able to find everything through Advance Auto Parts, and in several different brands, with MOOG being the highest priced overall- I choose mostly TRW. If you have a store locally, you can save a BUNDLE on shipping, plus not having to ship something back if it is wrong. Just my 2 cents. cowboy Last edited by cowboy33713; 04-30-2005 at 09:12 AM. |
