Old 04-29-2005, 09:56 PM   #1
dustysdaddy
89 burb engine oil cooler
I just went to change the oil on my 89 GMC burb SLE and discovered she's gotta engine oil cooler with lines coming off the block above the filter. Does this means I need more oil than a standard five quart V-8 ? It's a 350 with TBI and 67,000 original miles.
dustysdaddy is offline   Reply With Quote
Old 04-29-2005, 10:35 PM   #2
screwballl
Tonawanda 454
screwballl's Avatar
usually that just adds at most 1-2 quarts but make sure you get the old stuff out of there of course
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 04-29-2005, 11:49 PM   #3
dustysdaddy
will it drain on its own?
Since the cooler and lines are mounted above the filter, when I remove the filter will it drain on its own? Or do I need to disconnect the lines and drain them?
Old 04-30-2005, 12:34 PM   #4
skillet
skillet's Avatar
I have the same year suburban with oil cooler. The Chilton's manual(1988-96) says, "If the engine is equipped with an oil cooler, this will also have to be drained, using the drain plug. Be sure to add enough oil to fill the cooler in addition to the engine." I assume they're talking about the oil pan drain plug. I've never added any extra oil though, just the normal 5 quarts. But, you're question makes me wonder if I have been doing it right. I bought it with 114K and it now has 163K. At least it has seemed to have worked for the last 49K miles with no problems and it still runs great, even after a trip to Utah over some pretty steep mountains and back to Texas.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 04-30-2005, 02:13 PM   #5
u2slow
Web Wheeler
u2slow's Avatar
You could loosen one line... maybe easier near the radiator end... and blow it out with compressed air.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 04-30-2005, 05:22 PM   #6
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
I never drain mine, unless it drains along with the filter. Makes sense that since it is higher than the filter, it would drain into it. Maybe I'm doing it wrong as well though. Truck still runs flawlessly at 170k, I'm really not that concerned about it.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
