Certified Truck Nut
ok to lower with springs??
i have been looking at 3" drop front springs for my truck, but it says to use them with drop spindles...does this mean that they should not be used if you dont have drop spindles already?? If i did use them would i be able to line the front end up ok once im done?
thanks later Dan
1982 GMC Sierra Classic 1500 Longbed 350, TH350, 3.73 10 bolt soon to be slammed |
Keepin an eye out
I did a 3-5 spring drop on my '70 and was able to have it aligned, but it was close.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Certified Truck Nut
how's it ride?
thanks Dan
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
No, you don't need to use them with spindles. If you are going with a 3" drop, why not get 3" spindles. It will keep the same ride quality you have now.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#5 | |
67 is sold
As far as I know, the only company selling 3" front drop sprints is CPP... http://www.classicperform.com/ Like many other here, I went with a setup from www.earlyclassic.com ![]() |
