BlahBlahBlah
trick in getting this off?
this is my brothers truck. 65? anyway he cant get this off. is there a trick to it or is he just a puss?
why do you want it off? i've never seen anyone remove one before....but my vote is puss lol
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
Got Light Emitting Diode?
why would he want to take that off??? puss yes, but also i dont think he has 6'8" of body mass to throw into it either
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Keepin an eye out
Maybe he wants to change the wheel cylinder?
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
F.A.S.T. president
![]() Join Date: Sep 2003
that doesnt hold the wheel cyl on. But you will need a good impact if you want to get that off with no sweat. Or you can add a little heat to the back and some muscle to pry it loose.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
got boost?
not questioning your motives for removing it, iirc an impact will help a bunch.
i seem to recal there is a nut on the backside.maybe not. been awhile since i've been there. add some heat then, use an impact.
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" ![]() |
If you want to replace the wheel cyl you have to take the anchor pin off, for it holds the wheel cyl on. Get you a 3/4 inch drive socket set, it has a long handle ratchet.It will come right off, I just replace my wheel cyl on my 68 been on for 37 years came right off. If you don't have a 3/4 drive, or can't get one from a frind, you can get a loaner from AutoZone.
98 Chevy Z71 1500 extended cab 99 Dodge carvan es 68 Chevy C10 LWB 50TH 396 eng 400 Trans 62 Wheel Horse tractor in good shape |
That thing has a sort of washer on it that is likely bent over on one of the faces of the bolt part. You have to bend that back to get it off. I just used a socket & a breaker bar to get mine off. The cylinder is attatched with two bolts that go in from the back of the plate on my truck on the rear. Can't remember if it's the same on the front,.
I got a bench seat baby, you don't have to sit over there. |
BlahBlahBlah
thanks for your responces. he said it needs to come off to get the wheel cylinder off. looks like he just needs some heat and leverage.
im looking at the pic...it sure looks like the wheel cylinder bracket is held on by that. Last edited by CG; 05-07-2005 at 06:17 PM. |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
that does hold the wheel cylinder on! a socket & a looong handle will take care of it. You need to bend back the little tang that locks it in place, but i looks from the photo that that has already been done. I got mine off 2 summers ago with a long breakerbar.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
I'm watching you!
Did mine around a month ago on my 68...the driver side took heat, pb blaster, and a big can of whoop a** to get it off. The passenger side took only a little force. Breaker bar didn't help me at all on the driver's side. Just stick with it and it will come off eventually.
Good luck! Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
F.A.S.T. president
I thought all the wheel cyls are held on by the two bolts in the back. What makes these diffrent the year or that they are in front?
Hey thanks for all the responces. But first off, I'm no puss, as a matter fact I got a lot of ass behind me, 6' 280. I'll make sure the washer is bent all the way back and try the heat and or the breaker bar. I've used the 3/4 drive, tried the hand held impact wrench. May need to switch to one with a aircompressor.
huh?
![]() Join Date: May 2000
I had to use a pneumatic impact to get mine off the 68 last month. I'm 6' 3", 320 and I couldn't budge mine with a breaker bar and a cheater. Try the pneumatic impact, and good luck!
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#15 |
I got mine off with a 1/2" breaker bar.As far as the washer behind it good luck finding one,I looked high and low for those washers as I am doing a frame off restoration and really wanted it to be original.Any way,I ended up using a little loctite when I put it back together.
