Old 05-11-2005, 12:04 AM   #1
kaycee
kaycee's Avatar
Talking Sound Deadner
What have you guys been using for sound deadner in the cab of your truck's,I am looking for a cheaper but reliable alternative than Dynamat?
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 05-11-2005, 12:20 AM   #2
skokie
skokie's Avatar
There have been some folks up here that used brown bread.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 05-11-2005, 12:23 AM   #3
71-longbed
Its Magically Delicious
71-longbed's Avatar
I too am in search of a cheap alternative to dynmat and brown bread ....
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 05-11-2005, 12:54 AM   #4
68LSS1
68LSS1's Avatar
There have been quite a few posts about this on this forum and a lot of others. I'm going to use Lizard Skin on mine. It's a spray application type. It's gotten good feed back from those that have tried it. Plus it has thermal properties that the Dynamat does not have unless you by the liner that goes on top of that. (That is the Dynamat Xtreme.) Another bad point besides the cost is the weight. I'm trying to keep my truck on a diet and don't want to add all that weight. Don't get me wrong, Dynamat is the best stuff out there IMO. Fatmat calls itself the Dynamat Xtreme alternative so you might want to try them out. Mr Gasket has recently came out with this stuff. Don't know of anybody who's tried it. Here's some stuff sold by Route 66. There is also Brown Bread from B-Quiet. It also compares itself to Dynamat. Actually, Brown Bread has been replaced by what they now call Ultimate.
Basically, I've done a lot of research. What your after is the NVH values of the products. Make sure you read the fine print as some of the liners require a second material OVER them to control heat. If that's not a issue then no problem. Most of the paintable types do not have any thermal protection. A lot of the products have changed since they first hit the market. Dynamat being one of them (due to odor). I think the Fatmat or B-Quiet products will give you good performance for the money. There has been some issues with installing the cheaper stuff to roofs and it not staying after the sun had been beating on it but we are dealing with trucks so that will not be a issue. Also most of these products don't cut down noise a whole lot. If decreasing noise is your goal, get some Fatmat or B-Quiet and put in the doors and maybe firewall and get the good 1" jute padding under the carpet. Make sure all holes are sealed in the firewall and floor.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 05-11-2005, 04:28 AM   #5
71-longbed
71-longbed's Avatar
my biggest thing is .. i want something that won't soak up water .. my kickpanels leak alittle ... and i dont want water being held against the floor boards
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 05-11-2005, 06:14 AM   #6
Terry Peerson
I don't know if it's any cheaper, but I used Accumat from Scosche Enterprises in my VW. It is easy to use and works pretty good. Scosche also has a website you can check out if you want to.
T
Terry Peerson is offline   Reply With Quote
Old 05-11-2005, 07:30 AM   #7
cdowns
cdowns's Avatar
on my streetrod highboy i'm going to be using the lizzard skin that was mentiomned before, you paint it on and the thing i like is it's sandable and you can paint over it if wanted and it has a 500degree temp useage.
alot of people are useing bedliner products inside the cab, a big misteke in my book because with the uneven textured surface it's got to be a big dust and dirt trap over the coming years and once it's done like that there's no easy way of getting rid of it
Old 05-11-2005, 09:28 AM   #8
ChevyDude
I used DynaMat Extreme. It's cost some, but it works very well and is easy to install. You get what you pay for.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 05-11-2005, 09:46 AM   #9
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
I use the Dynamat Xtreme and like was said before, you get what you pay for. I haven't had any problems with it and it was easy to install. Use it and you will be happy with Dynamat.
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
