Old 05-15-2005, 08:34 AM   #1
guyryan100
guyryan100's Avatar
brake pedal goes soft when engine is running
I'm certain there's no air in my brake lines as I've bled, pressure-bled, reverse pressure bled, and bled again. The pedal feels firm when the engine is off (I think it could be a bit firmer but there's good resistance from the pedal). When the engine is running the pedal drops to the floor with the slightest press and I have to cram it down to stop the rear tires when idling in reverse (or drive). Rear tires are off the garage floor. My cylinders are new, lines are new, rubber hoses are about 1.5 years old but have only been driven with once.
guyryan100 is offline   Reply With Quote
Old 05-15-2005, 08:52 AM   #2
cowboy33713
Howdy:
It's been some years since I've experienced this, but as I recall it, a rebuilt Master Cylinder (and rebleed of the entire system after installation), provided the cure. Just my $.02, hope it helps.
cowboy33713
cowboy33713 is offline   Reply With Quote
Old 05-15-2005, 01:28 PM   #3
NPilot1975
NPilot1975's Avatar
Sounds like your booster is bad. Do you have the vaccuum line hooked up to the booster?
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 05-15-2005, 02:05 PM   #4
guyryan100
guyryan100's Avatar
yes, vaccuum to the booster is hooked up. How could a bad booster cause the problem? If it wasn't holding vaccum wouldn't that make the pedal firmer instead of softer? Can a booster over-boost?
Old 05-15-2005, 02:28 PM   #5
NPilot1975
NPilot1975's Avatar
yeah, you are right, I was thinking about something else. I was thinking bad diaphram, but it would give you a firmer, not softer pedal
Old 05-15-2005, 04:37 PM   #6
guyryan100
guyryan100's Avatar
Well, new master cylinder and re-bled, same problem. I made sure the rear brakes are adjusted nice and tight - even made them a hair too tight to be sure. Still have no resistance on the pedal with the engine running.
How much resistance should I feel in the pedal with the engine OFF? Seems firm but to me it seems like it could be firmer. Regardless, a little bit of pressure on the pedal does engage the brake to the point that I can't turn the tire by hand. Granted the 350 might be a bit stronger...
Old 05-15-2005, 04:51 PM   #7
toddtheodd
The oddest Todd around
toddtheodd's Avatar
How much cam are you running? You might have too much cam to make enough vacuum for power brakes at idle.
Did you check the rubber brake lines? They could be bulging when you hit the brakes.
Other than that, I have no clue, so I'm spent.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 05-15-2005, 05:32 PM   #8
guyryan100
guyryan100's Avatar
if I disconnect the booster, fire up the engine, put it in reverse with the wheels off the floor, it is still a pita to stop the tires. Takes more pedal pressure than it seems like it should. So I'm going to do some more bleeding (why not) and inspect the flexi lines to see if something's killing my fuild pressure.
Old 05-15-2005, 10:30 PM   #9
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
Does it WHOOSH Inside?
Do you here a Whooshing sound inside when you hit the brakes? If so, bad booster seal. If you have rebuilt the engine since you last used the brakes, then toddtheodd could be right if you replaced the cam with one with ALOT more duration. In that case, you may need a supplemental booster can. I have one from Cam Dynamics on my Chevelle. Nobody thinks that boosters go bad, but they DO. I wish you luck, Hot Rod
hotrodmtodd is offline   Reply With Quote
Old 05-15-2005, 10:35 PM   #10
Mudder
Mudder's Avatar
If air rushes from the booster hose after you shut the truck off off its ok. Go out and pull the hose off of the booster after you shut the truck off. If its ok its the master. IMO Could be the vacum issue also.
Mudder is offline   Reply With Quote
Old 05-15-2005, 11:07 PM   #11
cowboy33713
Howdy,again.
Did your truck come with power brakes, or is it a conversion? Is there an adjustment to the rod from the pedal to the master cylinder , for pedal height before the pedal is depressed( rod too short)? ( haven't gone out to check mine; everything I've ever changed out was a direct remove/replace). Does anyone know if a malfunctioning proportioning valve might cause this?
-cowboy33713
