Box Wood Done!
Finally finished box wood floor today!
Just finished counter sinking mounting bolts and offset washers.Was dissappointed with GMC pauls box wood info for board cutting info as it should be a little wider boards but I was able to space out enough to cover.Not his fault as I should have just measured for myself.Anyway here it is.
Looks great! Thanks for the info on the measurements, I was planning to use them. What did the wood cost you? Any tips?
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
Keepin' It Stock
Bed wood looks good. Glad you were able to space them out. Actually, most of the info on GMCPaul's site came from Jeff Nelson's web site.
If you would measure and give me the correct dimensions, I would work up some drawings and post them on my web site for those doing this in the future. That wood's too expensive to mess up with bad instructions.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
Great looking job
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End Early Classics 6 Lug Disc Brakes and Spindles All Stainless Lines |
Solver, the bed looks great. I need to get with you about the hole locations and the dimensions. About to do the same thing. My bed wood wasn't pre-drilled. Having tough time firguring it out.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
OzarkHillbilly in Atlanta
That looks great ,,,,, hope to do mine someday.
I know it's oak but do you know what kind of oak ? and where did you get it ?
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
Livin' it up.
![]() Join Date: Nov 2001
wow that looks awesome, really satisfying when done too!
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Saving 1 truck at a time!
Beautiful job....makes me want to do a wood bed...no matter what the cost or heartache...the best of both worlds for us old "wood butchers!"
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Lookin real fine! I'm also interested in getting proper specs. I replaced the old pine about 5 years ago with 3/4" plywood. The stuff is still solid but I'd like to get it back the way it was. I'm planning on using Australian gumwood, I know, a bit pricey but it lasts 3X longer than any other wood you would care to name. A friend's bro-in-law imports wood so I figure I can get a good deal. The rest will involve making router and drill bits dull, lol.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
I plan on just taking the factory boards out of the '68 and duplicating them. Measure it myself...
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
![]() Join Date: May 2002
I suspect that those dimensions originally came from GM and that they were established to allow for bed manufacturing variances as well as wood movement with humidity changes--keep in mind that these beds are rained on many times in their lifetime! No surface treatment known to man will prevent wood moving as humidity changes--varnish certainly won't. Finally, oak was used in this case which is notorious for movement.
If someone really wants a nice job, he should measure his bed and adjust the board widths accordingly.
Stepsides look like real trucks! Smitty ![]() |
![]() Join Date: Oct 2001
Super looking job Solver. Did you paint the strips or powder coate them? I've never gotten the boards out of the box to see if mine are drilled or not. The old ones are good enough for patterns though.
'69 swb stepside in progress. '59 Corvette lifetime project |
