The oddest Todd around
84 degrees out, so of course the window regulator breaks!
Okay,
I looked (skimmed through) in the faq, and couldn't find anything on how to change out the window regulators. Also, I need to know how to change them when the window is stuck up. Crank will not move. I can roll the window up (to a certain point of course ![]() Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? Last edited by toddtheodd; 05-17-2005 at 04:21 PM. |
nothing?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
Its Magically Delicious
i feel your pain.. my driver side windows been stuck up for some time now .....i figure im going to have to cut it out to get the window down so the vent window can come out and the regulator can be changed
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
That is a tough one. I would try to get the regulator disconnected from the window sash. You won't be able to remove the regulator but you should be able to get it off of the sash and drop it down. Not knowing what happened to the regulator, I would suggest care as the arms are sharp. Once you get the regulator off and out of the way you should be able to push the window down. To remove the vent window assembly, remove the two bolts that hold the rear window track and push it backwards so that the window can be pushed backwards. Remove the screws holding the vent window assembly in and remove it by manuevering it up and out.
Once the vent window assembly is out you can remove the window regulator after pushing the window back to the top. Lastly you can remove the window. Jim Last edited by JimKshortstep4x4; 05-17-2005 at 08:20 PM. |
window sash?
#6 | |
http://community.webshots.com/user/hotrodhorn |
The window sash is the metal part that the glass sets in and the regulator hooks to.
Jim |
So I can just cut the regulator with my sawzall where the bar comes over to the slanted piece of metal on the latch side of the door. (the slanted piece being the window sash?) That should let me lower the window right? Then after I take the vent out, the glass comes out next?
I'm going to take pictures while I do this and put it into the faq section. Todd
thanks todd ... im happy that it hasn't gotten very warm here in the Willamette Valley yet .... i definately plan to fix my window soon and i could use any and all help thats out there ... last summer was no fun with a window thats suck up and No AC
