Old 08-01-2002, 06:36 PM   #1
LT-102
Will 285x60x17 fit my truck?
Looking at a good deal on wheels & tires if they will fit my truck. They are 285x60x17. Believe the backspacing is 4-1/2. I have a 71' C20. The wheels are about 100 miles away so it's not just a drive around the corner for a test fit. Thanks
LT-102 is offline   Reply With Quote
Old 08-02-2002, 07:37 PM   #2
LT-102
Somebody out there has to be running big tires. A little help please.
Old 08-02-2002, 07:52 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
They should fit. Approx 30" tall and probably mounted on 8" wide rims. I'm running 325/60R15 on 15x10 w/ 4" backspacing. Of course mines 4wd. I've heard of people running 31x10.5R16.5 on 2wd 3/4 ton trucks.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-03-2002, 12:51 AM   #4
Hutch
Hutch's Avatar
I have 31's 0n 15x8 with 4 inck b/s stock 71 1/2 ton suspension
I don't think you would have a problem that could not be easily cured.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 08-03-2002, 09:06 AM   #5
Chevyc10!
Chevyc10!'s Avatar
It will be close...
I have 275/50/17's on a 9.5" rim and I barely have 3/4" clearence on the inside of the rear fenders. Mine is lowered 5" in the back. Personally, I think 285 may be to close if your going to lower it. If not, then go for it.
68 SWB
The Surgeon General doesn't say anything about smoking a Ford!!!
Would rather be ran over repeatedly by a Chevy than drive a Ford!!!
Paralyzed from the neck up and confined to a hat!
Kathleen, Georgia USA
Chevyc10! is offline   Reply With Quote
Old 08-03-2002, 04:39 PM   #6
white68chevy
Dont know if this will help you out or not but i am running 285/70 15 on an 8 in wheel and i have plenty of room. And mine has coil springs that will make a difference also. Good Luck I just did the tire and wheel thing and I know how confussing and agrevating it can be.
1968 swb
IM-Bufechevy56
If its to loud then your to old
white68chevy is offline   Reply With Quote
