Dash pad removal?
I'm looking for instructions on dash pad removal. I can't seem to figure out how to search, but I'm sure it's been discussed here before. Someone point me in the right direction please...
Real Name - Brandon Current Vehicles: 1977 C20 Silverado 454/TH400 3.73s 1989 Jaguar XJ6 in the middle of an LT1/4L60E swap |
search is disabled at the moment....
as far as removing the dash pad.. remove the gauge bezel, then remove the 5 or 6 screws across the passenger side, then open the passenger side door and remove the one large screw on the end of the pad.. Then you should be able to pull the pad towards yourself (if sitting in the middle of the cab) to release the clips.. then drag it out of the door... may take a bit of wrestling with it, but that is the jist..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Thank you for the quick reply!
mine has the screws in the bezel and the clips that it
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
Getcha' Pull!!!
mine had the screw on the p/s end but that is missing now and my glovebox won't open unless i lift the dash up a hair.....but that's all there is to it. Do it a few times and then you'll be a pro at it. Just take your time and be careful. that's all
Rest In Peace Dime ![]() Last edited by 87_Blazer; 05-20-2005 at 10:26 PM. |
