Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 05-22-2005, 01:31 PM   #51
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Originally Posted by 1FaastC10
just a right time, right place deal? or do they normally go for that from the particular seller you bought them from?
If you are referring to the mirrors yes!! Right place right time I guess!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 05-22-2005, 01:36 PM   #52
phantom dually
Originally Posted by Truckhead
Phantom, you given up on Airride suspensions? Your trucks coming along good.
I would possibly like to do airride in the future but at the moment Im going to just go static drop. In the rear I am setting up the ladder bars so Ive not really even thought about what it would take to make it work. I could do a simple front setup and leave the adjustable coilovers on the rear. Another thing I could do is leave the tanks and all under the hood and frame and just go front to keep in clean. Im gonna ride the static for a while and if its not low enough then bags it is. The rear is adjustable like crazy!!
Old 05-22-2005, 01:38 PM   #53
phantom dually
I got the whole frame cleaned down and primed and painted the rear half yesterday. Here are a few pics. Hope to get the rest done throughout the week so I can get the frontend back together next weekend.
Old 05-22-2005, 03:40 PM   #54
Paint is good...means assembly not far.
Nice looking job on it. I'm looking forward to see what she looks like all back together.
Old 05-22-2005, 04:59 PM   #55
1FaastC10
1FaastC10's Avatar
shouldnt be a huge deal to bag the rear i wouldnt think. bridge your notch right above the axle, install bag mounts and bags. with ladder bars you could potentially run into clearance problems when aired down depending on your ladder bars.
1FaastC10 is offline   Reply With Quote
Old 05-22-2005, 06:31 PM   #56
phantom dually
The way I see it I can slam the rear and run bags on the front and I would be OK. I did this on a 83 LWB with hydros on the front and had no probs. I have to finish up a little paint work then get to work assmebling the front end. Send the rearend out this week to be cut down and fitted with axles.
Old 05-22-2005, 07:18 PM   #57
1FaastC10
1FaastC10's Avatar
is the truck a shortbox or a longbox?
Old 05-22-2005, 10:08 PM   #58
phantom dually
SWB 92 stepside. First pic in thread
Old 05-26-2005, 10:41 PM   #59
phantom dually
Took the rearend to be pulled apart. Checked the spline on the side gears so I could order axles. Called up MOSER and got a set of 30 splines. I know the more splines the better but I wanted to retain the POSI that I got with the rearend. I could have changed the side gears but finding a set is pretty hard to do and from what I hear pricey!! Anyhow each axle should only end up being around 22" in length which gives less area to break. I am going with BIG FORD housing ends and using weld on brake kit to finish. Should be able to get the rearend back in the truck in 2 weeks or so.
Old 05-30-2005, 12:51 AM   #60
SCOTI
SCOTI's Avatar
Cool progress PD.
Just a thought.... why not consider AirRides Shockwave 9000? They should be small enough to fit where coilovers were intended (5" dia) & they can accommodate 1200lbs load capacity @ 100psi or 2400lbs combined.
IMO there's nothing wrong w/static, but if you wanted air you could prob set it up now to make it easier to switch later.
Later, Scot.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-30-2005, 10:34 PM   #61
phantom dually
Yeah thats not a bad idea. They are kinda pricey though. I guess by the time I welded new brackets in the rear and so forth it would be worth it. Also I could get a little cash for the QA1 coilovers that I have.
Old 05-30-2005, 10:38 PM   #62
phantom dually
Here are a few progress pics from the long weekend. Finished priming and painting the rest of the frame. Got the upper and lower arms on the front. Also got the Belltech 3" coils in the front as well as the DJM 2" spindles. And dont forget the DOESTECH shock up front. Hope to make little more progress through out the week. I feel that alot of the hard work is done, so everything else should be straight forward from here. Time to start cutting on the bed. I want to get this thing on the road when the wheels are here in roughly 6-7 weeks from this post.
Old 06-05-2005, 10:34 PM   #63
phantom dually
Got the narrowed rearend back yesterday. Looks pretty sweet. I will get a few pics and post asap. Plan to get it painted this week and under the truck.
Old 06-06-2005, 06:15 PM   #64
Tracy Focht
Tracy Focht's Avatar
Eric...what do I think? I think you make too much money!
pics of the motor...........
Tracy Focht is offline   Reply With Quote
Old 06-06-2005, 10:11 PM   #65
phantom dually
Motor pics coming soon!!
Old 06-06-2005, 10:21 PM   #66
phantom dually
It is possible that I make too much money but, I doubt it. I would still rather have your job. Doing something everyday that you really dont enjoy SUX!!
Old 06-07-2005, 09:33 PM   #67
phantom dually
Here are a few progress pics. A few of the narrowed rear Dana 60 and a couple of shots of my 496 Stroker engine. (FOR TRACY FOCHT).
Old 06-07-2005, 09:37 PM   #68
phantom dually
A few more pics. Notice on the block I spent a few extra hours smoothing the factory casting marks off. While this isnt so apparent now, when the block is painted in should make it look great. IMO
Old 06-07-2005, 09:39 PM   #69
phantom dually
Picked up a Stillen bumper smoothy from EBAY. Got it for $80 shipped!! Im really not in need of it yet but it was a good deal!!
Old 06-07-2005, 10:13 PM   #70
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
lookin bad ass man
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 06-08-2005, 07:14 PM   #71
Tracy Focht
looking great Eric....that 496 will HUMP that truck
Old 06-08-2005, 08:28 PM   #72
99-2door
99-2door's Avatar
That is a nice looking engine. What kinda injection you gonna run on it?
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 06-08-2005, 09:08 PM   #73
phantom dually
Well injection is probably not going to make it!! I have a 850 Holley DP carb that has been modded that I will run for awhile. Maybe down the road I will get some type on FI system. Damn things sure take alot of tuning out of the picture once setup correctly.
Old 06-08-2005, 09:09 PM   #74
phantom dually
It ought to be fun. I plan to run the new TREMEC tko 600 tranny. Its a manual 5 speed. Nothing like rippin through the gears!!
Old 07-02-2005, 11:44 PM   #75
phantom dually
Got my Wheels in today!! Im pretty Happy about them!!! These are just the backs.
