I have a 72Blazer and I am wondering about some of the wiring.Does the yellow or purple wire go to the S terminal on the solenoid?Does my white and yellow wire that is crimped together with a 2 prong male connector go to the resistor,or does the brown with a white stripe?Where does the blue wire with a rubber boot with single female prong go?Also there is a 3 prong male plug on the right side of the Turbo 350 just below the trans cooler in and out fittings,what is it for?I got this harness quite a few years ago from Golden State Truck Parts.This was a frame off restoration that as you know can get prolonged some times.I would greatly appreciate any and all input.Thanks
Recovering Truck Driver
The only wires I can help you with are the purple and yellow starter wires, the purple goes to the s terminal, the yellow i think goes to the r terminal or whatever the other one is.
------------------ Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84 ralleys and 31/10.5s Angel girl: 67 Cutlass convertible 330, 3spd stick Greener: 90 GMC Jimmy 350/auto Chad Stephens Orleans,NE no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
