05-20-2005, 05:20 PM | #1 |
needin' money
another distributor question
Is there anything that will help your distributor? Because i was thinking that accel coil, but after reading the messages i'm not
05-20-2005, 05:51 PM | #2 |
Its Magically Delicious
be more specific please
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
05-20-2005, 06:42 PM | #3 |
You want a little more power out of your distributor?
Your talking about replacing the coil and module? New cap New rotor Better plug wires Timing changes?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
05-20-2005, 07:20 PM | #4 |
needin' money
yea, i need a little more power out of my distributor. I replaced the cap, rotor, spark plugs,plug wires and we set the timing . I used an accel cap, rotor, wires,and acdelco r45ts plugs.
05-22-2005, 09:08 PM | #5 |
needin' money
anything?
05-23-2005, 12:34 AM | #6 |
Cruzzzn' Vet
I used to run the Accel coil on my 83 with HEI but now run the HYPERTECH Super Coil which really improved the overall performance , the HYPERTECH has a higher output than the Accel.
John 83 Silverado KN HYPERTECH FLOWMASTER |
05-23-2005, 01:59 PM | #7 |
You could get the MSD module and coil.
You will notice a little difference in performance, but not very much. When I switched only the module from stock type, my idle jumped 100 rpm. Not sure why it jumped my idle up, but it did. I corrected the idle and it ran a little better and idled a bit smoother.
05-23-2005, 02:04 PM | #8 |
needin' money
such as from www.summitracing.com part#msd-8225, is that right phoenix
05-23-2005, 02:13 PM | #9 |
Remember that the module only replaces 4-pin modules!!!
Some stock distributors didn't have 4-pins, they had more. MSD 8501 HEI UPGRADE KIT MSD 83645 MODULE ONLY MSD 8225 COIL ONLY
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 05-23-2005 at 02:16 PM. |
