Old 05-23-2005, 12:19 PM   #1
69sixpackbee
Can Anyone Desktop Dyno My Combo?
I am trying to dial in my 402 with the Megasquirt EFI system I built and installed and I need some fairly close HP & torque figures I can plug into the VE map and finish setting it up. If anybody has a Desktop Dyno that can help me out I would greatly appreciate it!
Heres the scoop:
Stock bore 402
Stock CR (9.0:1?)
Comp Cams XE250H cam (470lift/250dur Intake 475/260 Exhaust 110 degree center) 600-4800 RPM range
Performer dual plane intake.
Sock oval port heads
Stock exhaust manifolds w/ dual pipes
Did I miss anything??
Thanx!
69sixpackbee is offline   Reply With Quote
Old 05-23-2005, 12:24 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
what size carb are you running????
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 05-23-2005, 12:25 PM   #3
69sixpackbee
I have a 2bbl TBI from a 454 on it. Twin 51MM bores with 85lb/hr injectors.
Old 05-23-2005, 12:33 PM   #4
Dean23
68cst_ss490
Dean23's Avatar
I got about 308 hp @ 4500 rpm and 401 ft/lbs @ 3000 rpm. the numbers hould be slightly higer though. there isnt a spec for throttle body injection. if you throw a set of headers on ther you should get closer to 340 hp and 435 ft/lbs
Dean
edmonton,canada
a winter wonderland
Old 05-23-2005, 03:01 PM   #5
69sixpackbee
Thanx Deano!!
