08-01-2002, 07:07 PM | #1 |
Bed wood finishes
I have seen a few posts of photos of bed wood the last few days. What did you guys use for varnish. I went to local Marine West store today. They have the boat stuff for $15.00 a pint and calls for 3 coats. Must be something better.
1969 GMC S/B S/S 3" drop |
08-01-2002, 07:13 PM | #2 |
member #16
You can buy exterior uv resistant marine urethane finish at a hardware store alot cheaper than that. I paid less than that for a quart.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-01-2002, 09:15 PM | #3 |
Been there.... dont that!! A varnish will never hold up to your liking because you have to recoat every so often because the stuff loses its strength on fighting the elements. I used a supposed marine urethane product on my wood and it lasted a whole 30 days before water had gotten underneath and started to turn the wood black from mildew. What I did was strip everything, restain, and I shot it with automotive clear. I used almost a gallon of that stuff coating all the sides. And if you don't know anything about prices of auto clears, well lets just say its double what you were quoted for the varnish. Expensive yes!! But let me tell you, this stuff has held up great now!! Theres some certain procedures you must follow when trying to spray auto clear on wood, but its nothing major.
My engine is stock... trust me ;o) Last edited by cali_surfer; 08-01-2002 at 09:17 PM. |
08-01-2002, 09:18 PM | #4 |
Here's a pic to prove I'm for real
My engine is stock... trust me ;o) |
08-02-2002, 11:30 PM | #5 |
What prep is necessary to spray over wood? Probably can't use an oil base stain but how about a water born stain?
'69 swb stepside in progress. '59 Corvette lifetime project |
08-04-2002, 07:45 AM | #6 |
I picked up some poly-urethane at the local hardware store. It "says" it protects against UV rays. Cost $35-$40 a gallon. Thought that was expensive, but if it works, what the heck? Looks good after 3-4 coats.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
08-04-2002, 01:49 PM | #7 |
bruce horkey says 5 coats minimum. start with like 75/25 varnish/thinner, for 2 coats, then one of 90/10 varnish/thinner, then 2 of 100% thinner. thats what i did, and im happy with it. good luck, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
08-04-2002, 01:50 PM | #8 |
oh yeah, that is marine spar varnish
08-04-2002, 02:39 PM | #9 |
If it's going to be rained on or washed-----spar (or any other kind) varnish will not last. Cali_surfer is right--use clearcoat.
Stepsides look like real trucks! Smitty |
