Jamie 72 and I are working a deal on a PS gear box for my 71blazer. He found a 79 4x4 parts truck and the belief is that the PS gear box is the same. Anyone with any first hand experience here that can verify? Would 1/2 ton verses 3/4 ton make a difference?Thanks---Huck
------------------ 72 Cheyenne, 350, 5spd, LWB, Super trim. 71 GMC JIMMY 4X4 --needs stuff-! |
This is what Hollanders shows will work:
BLAZER/JIMMY (full size) 69-76 Power Steering; 4x4 CHEVROLET PICKUP TRUCK 69-76 Power Steering; 4x4 GMC PICKUP TRUCK 69-76 Power Steering; 4x4 SUBURBAN 69-76 Power Steering; 4x4 7825868 $545 obs Less upper jacket, upper shaft, pitman arm, shifting mech. and wheel 1249 fits by including coupler. It also shows these will work: BLAZER/JIMMY (full size) 77-79 Power Steering; 4x4 CHEVROLET PICKUP TRUCK 77-79 Power Steering; 4x4 GMC PICKUP TRUCK 77-79 Power Steering; 4x4 SUBURBAN 77-79 Power Steering; 4x4 464160 '77-78 $585 obs 7832402 '79 $585 obs Less upper jacket, upper shaft, pitman arm, shifting mech. and wheel. 959 fits by including coupler. It looks like the 79 box will work if you get the coupler (I assume this is the rag joint).
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
![]() Join Date: Feb 2000
The gear boxes are the same externally buthte gearing inside is different. It should bolt right up and it doesn't make a difference between 1/2 and 3/4. The rag joint may be different but they are easy to get.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Thanks guys for the feedback. Sounds like it will work out. Now on to the next interesting opportunity. Huck (:> )
