Old 05-24-2005, 02:55 PM   #1
matthufham
power windows/locks
i might part out a 77 chevy with power windows and locks, i was wondering can i just switch window regulators into my 72, then wire it, get the switches, and get it to work? i'm not sure if it's a direct replacement or not. also on the locks, i was thinking switch to power, and that will solve my shut the door, and then lock it with the key outside problem. will it?
matthufham is offline   Reply With Quote
Old 05-25-2005, 02:45 PM   #2
matthufham
ttt, anybody?
Old 05-25-2005, 04:01 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
I don't know for sure, but I don't think that would work without some mods. The doors/windows are definately different, so I don't think a regulator swap would be simple. The door lock swap may work, but I think you can buy kits (I think they are both around 150 each) for the windows and doors that are direct bolt ins AND you will have a remote for your door locks, therefore don't need to use your key again if you dont want to. If I'm wrong y'all go ahead and flame on, that's my two cents.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-25-2005, 05:29 PM   #4
matthufham
i'm trying to save as much money by parting my 77 chevy and using everything that'll work. i'll just have to get into the door and compare the 2. thanks
Old 05-28-2005, 12:20 AM   #5
hilljob26
hilljob26's Avatar
my power window setup that i bought for my 72 said that it would work up to 74,i dont know if 74-77 is different,but i hope that helps
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 05-29-2005, 10:33 AM   #6
modifiedGMC
It depends on how "involved " you want to get. I bought a 1979 caddy for $100 to get the 425 out of but found it was bad so I took the power window regulators, switches and wiring out. With a little modifying to the regulators and some to the door it self I got power windows. I also used the power locks also it was easier, just a couple of holes to drill and attach the rod to the lock mechanism and run the wiring. I even used the disc rear end from the caddy but had to make a driveshaft, so after using a 79 disc front end I now have four wheel disc brakes. I well have got my $100 in parts from the car and can still sell the motor and 400 tranny then haul the body to scrap. Some times it may take a little more effort to do something but in the long run it's more fun and saves a little money.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 05-29-2005, 10:44 AM   #7
Swbman
Way to go ModifiedGMC, thats the way Im used to doing things,theres always a way to make things work if you take the time to figure it out, Im not much into conversion kits,all the ole guys I know have been doing this stuff for years without instructions or high dollar kits,why spend money when you can buy a donor vehicle take what you need and sell or scrap the rest.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 05-29-2005, 05:46 PM   #8
matthufham
that's what i'll probably end up doing myself if it's not to hard to modify. i wanted to know how easy it would be before hand though, guess i'll find out soon enough.
