Old 05-27-2005, 10:48 PM   #1
shanetch
frame vin #
I am trying to figure out what year frame that I have. Any suggestions on were to look? Is there a web site that tells what the numbers mean. I also need to know what axles I have. I believe it has the 12 bolt rear and the 44 front. It is a project vehicle. Any help would be appreciated. The truck has a 72 cab. How can you tell the difference from 67 to 72 4x4 frames?
shanetch is offline   Reply With Quote
Old 05-27-2005, 10:50 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Most frames were stamped in the general area of the steering box
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-27-2005, 11:08 PM   #3
402Bowtie
402Bowtie's Avatar
My '72 frame is stamped right below where the doors would be. I believe it is stamped on both sides of the frame.
402Bowtie is offline   Reply With Quote
Old 05-27-2005, 11:19 PM   #4
HuggerCST
HuggerCST's Avatar
My 72 is stamped on top of the frame rail, just behind the steering box. (between the steering box and the firewall) I've been told that they are also stamped under the cab, as 402bowtie said.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 05-28-2005, 12:14 AM   #5
Rod
And the first number of the frame stamp represent the year of frame typically. Second letter or number represents assembly plant the rest is the sequence same as vin tag. Most frames, some dont..then you gotta know the little differences, like spring purchase types and brackets and such. Can be done though fairly accurately.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-30-2005, 01:43 PM   #6
shanetch
Thanks for your help. Where can I get the information to decode my frame numbers? You also replied to another thread that I posted about my vin numbers. You said that the 8 stood for a blazer, but I thought that a 6 stood for blazer. Any information that you can give me is very appreciated.
Old 05-30-2005, 05:40 PM   #7
crashz71
I just did a frame off restore on my frame the numbers were located in the
area of the steering box and on top of the frame about in the middle of the
drivers door. The numbers on the frame at the drivers door were not stamped
as deep as the other place. After etch primer and primer, paint, and two
coats of clear these numbers were a little hard to see. No problem with the
ones at the steering box location.
crashz71 is offline   Reply With Quote
