Old 05-27-2005, 01:46 PM   #1
willow72
willow72's Avatar
bowtie overdrives?
anybody running one of there 700r4 in one of our trucks? how well do they work with 307 rear gears?any better gas mileage and whats the rpms at 70 thanks for any answers also does anybody know a good tranny shop to get agood 700r4 if bowtie overdrives aint any good? o yea in dallas /ftworth area thanks again for any info, john
willow72 is offline   Reply With Quote
Old 05-27-2005, 02:37 PM   #2
smokekiki
Mike
smokekiki's Avatar
Tx Firefighter lives in Your area,He said he uses Pheonix transmissions.I have a bowtie in my suburban,and with 3.73's i am turning 2200 rpm at 60.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-27-2005, 03:46 PM   #3
pjmoreland
pjmoreland's Avatar
If you have 29" tires, then here's what the RPM will be at 70 MPH:
(70 mi/hr) x (1hr/60min) x (5280ft/1mi) x (12in/1ft) x (1/(29in x 3.14)) x 3.07 x .7 = 1744 RPM
That's pretty low. The vacuum switch that controls the torque converter clutch will probably disengage the clutch on the slightest hill since the engine will start to bog down.
I have a 700R4 in my truck with 3.73 gears, and my engine spins at slightly under 2000 RPM at 65. I'm confused by smokekiki's RPM at 60. Seems a little high for an overdrive transmission. It's about right for a non-overdrive transmission without a torque converter clutch. Either that or his tires are really small.
pjmoreland is online now   Reply With Quote
Old 05-27-2005, 04:35 PM   #4
smokekiki
Mike
smokekiki's Avatar
I could be remembering wrong,or my not so accurate factory tach,or a little of both. I am taking it out in a little bit.
Old 05-27-2005, 05:11 PM   #5
pjmoreland
pjmoreland's Avatar
Looks like you have quite the collection of trucks, smokekiki! I'd be impressed if you could keep track of the RPMs on all of those.
Old 05-27-2005, 05:47 PM   #6
Smitty
Smitty's Avatar
I have a Bow Tie Over Drive in my '71, with a 60 over 350, 3:54 gears (should have stayed with the 3:73's) 275/60 15's it turns around 2400 at around 70-75. Can't drive 65! You can't beat their TV Made EZ kit for setting up the cable. I've got somewhere around 50,000 on it and you can be sure that not a lot of them are easy miles. But mostly freeway! It seems my milage was better with the 3:73's. I do get around 11-12 the way it is now because my foot is usually stuck in the carburator.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-28-2005, 07:28 AM   #7
willow72
willow72's Avatar
ttt
Old 05-28-2005, 07:41 AM   #8
willow72
willow72's Avatar
i really want to know about what my rpms will be with a 700r4,307 rears, 31 inch tall tires at 70mph and do yall think that will work allright with the 307 rears i think a tranny shop would say yes that will work fine just too sell me one i really need yall help with this decision thank for any help you can give me, john
Old 05-28-2005, 07:53 AM   #9
krue
Designated A-hole!
krue's Avatar
Using the above equation and substituting 31" tire I get 1631 rpm. Kinda low.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-28-2005, 07:57 AM   #10
53burb
53burb's Avatar
I am planning on doing this swap shortly. I have a 3.07 that I need to install. The 700 has a lower first and second gear than the 350 or 400. I hope that will make up for the high gearing as far as the take off goes from a dead stop. I figure I will only use O/D once I am up to speed on the freeway. I don't think I will need or want it around town. The tires I was planning on using are about 26 inches in diameter. Here is an RPMcalculator. Your RPMs will be only about 1636 @ 70MPH. Kinda low, that is why I would only use O/D once I got over 60MPH on the freeway.
53burb is offline   Reply With Quote
Old 05-29-2005, 12:19 AM   #11
68Stepbed
68Stepbed's Avatar
I knew a guy that ran a transmission shop. He had a 71 with a 700R4 and 3.07 gears and 275/60/15 tires and said his ran around 1400 at 70. He hated it.
I would definetly go with a lower gear. If I go with a 700R4, I'm gonna install 4.11's in mine.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-29-2005, 08:48 AM   #12
willow72
willow72's Avatar
ttt
Old 05-30-2005, 10:57 PM   #13
djracer
djracer's Avatar
check with Bob he is the freakin MAN when it comes to a 700r4! http://www.darkhorsetransmissions.com/ Tell him Kevin Tolliver sent you he is a personal friend of mine and he has built atleast a dozen 700's for me!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-30-2005, 10:59 PM   #14
djracer
djracer's Avatar
I have had later model trucks with 3.08 gears and I was always happier with a 3.42!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 05-31-2005, 11:22 AM   #15
vfrdude
vfrdude's Avatar
I just went thru this - Installed 700R4 and had 3.07 gearing. RPM's way to low for hiway and I have smaller diameter tires than you do. I had 3.73 gears installed, and it seems to be the perfect gearing for all around driving.
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
