05-30-2005, 12:31 AM | #1 |
Long plug wires - where to buy?
I have a 72 with a 350 and am getting ready to switch from points to HEI. The dizzy is the easy part. The pita is trying to find the plug wires. I'm trying to go factory and need the wires that are long enought to go behind the motor instead of over the valve covers. I've been to six different parts stores and 2 GM dealers and no luck. I found a set in yellow but want black. I know they must be out there, any suggestions on where to find them?
Thanks, Scott |
05-30-2005, 12:37 AM | #2 |
18 Till I Die
Try Moroso or MSD. I bought a set in red for my big block in a universal kit and i cut/crimp the end and put on each wire as I made it. Routed them all around the back of the valve cover. that way they all fit to each plug perfectly. Had GM HEI wires before and thes are much nicer
05-30-2005, 12:44 AM | #3 |
Chinook Arch
I concur with kelsfine69. I just installed a universal set of black 8.5mm MSD Super Conductor wires on mine, and they are plenty long enough to route any way you want. They came with a tool to help trim the wires, and put the first crimp onto the terminals.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus. Elsie's truck 2.5" dual exhaust with Hooker Aero Chambers Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350 ECE drop 3.5/5 |
05-30-2005, 12:54 AM | #4 |
There was a thread about this a few months ago. Somebody said that Corvettes from somewhere in the mid '70s had ram horn exhaust manifolds AND HEI, so if you can get stock plug wires for that year of Corvette, they mount up perfectly, without the pain of having to attach the ends to the wires like you have to do with the high-end wire sets. I ran the Accel wires that you cut to length. I was able to make the length perfect, but I agree yellow is pretty obnoxious.
05-30-2005, 01:05 AM | #5 |
Designated A-hole!
73 or 75 vette wires. I don't remember which it is.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
05-30-2005, 01:07 AM | #6 |
Got Light Emitting Diode?
75 sounds right
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-30-2005, 01:08 AM | #7 |
Msgt USAF Ret
The corvettes that PJ refers to are the 1975 and up c-3 models with Hei ignition. My 74 still has points so 75 and up are the ones you want. They route down under the rams horn like he said. You may need to get the wire holders to keep them off the exhausts also.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-30-2005, 01:12 AM | #8 |
www.gmcpauls.com sells the little wire retainer clips that fasten to the oil pan. I installed a pair of these, and they worked out great. They keep the front wires from touching the exhaust manifold.
05-30-2005, 01:26 AM | #9 |
Designated A-hole!
I just used the stock wire holders.
05-30-2005, 01:36 AM | #10 |
~Rest In Peace~
[url]taylor wires
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex Last edited by fastwillie 696969; 05-30-2005 at 01:38 AM. |
05-30-2005, 03:16 AM | #11 |
My favs, Magnecor, sells black wires. Very informative articles at the top 4 links, as well.
And I 3rd or 4th the 75 vette app.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
05-30-2005, 12:06 PM | #12 |
Thanks for all the info guys. One last thing. I have the wire brackets that go at the back of the block and also the small ones on the block under the front 2 plugs. I see that there are also a set that connect at the oil pan? anyone have any pics? are there any other wire holders than whats been mentioned?
Thanks, Scott |
05-30-2005, 04:35 PM | #13 |
Here's a link to the picture of the one www.gmcpauls.com sells. It's not a very good picture. I installed two of these (one on either side) and they worked out great. There's a
http://www.gmcpauls.com/pictures/Plu...an%2067-72.jpg Here's an image from the 1972 Service Manual that shows the clips on the oil pan. You can see them next to the arrowheads pointing at cylinders 5 and 6. |
05-30-2005, 05:13 PM | #14 |
The oddest Todd around
While you're at it, pick up the spark plugs for the 75 vette as well. I can't remember the code for them off hand, but I think it included the letter X, which was for HEI.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
05-30-2005, 06:30 PM | #15 |
Sisyphus was my mentor!
I love my MSD Heli-core plug wires! (the blue jacketed ones) you can custom make them really quick & they lasted me 9 years with less than 200ohms per foot resistance at the end of 9 years! I had to change them out because the silicone jacket was breaking down. Just this past spring I installed new ones. for my 327 with hei I used unversal kit pn 3120.
http://www.msdignition.com/wire_2.htm http://www.msdignition.com/wire_3.htm
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
06-01-2005, 12:25 AM | #16 |
OK, I lied, one more question. I see in the diagram (thanks PJ) that there is one retainer connected to an oil pan bolt per side. The retainer from GMC Pauls says that the retainers are for one wire only. Did the factory retainers hold both front wires or just one? Does anyone have any factory retainers that connect to the oil pan they want to sell? Thanks guys
Scott |
06-01-2005, 12:33 AM | #17 |
I installed the clips from GMC Pauls, and they are the perfect size for two wires. I'm not sure why they say that on their website. I have one per side.
