Old 06-01-2005, 06:51 PM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
Picture of van tilt plug adapter PLEASE!!!!
Could someone post a picture of the wiring plug adapter that
you use to plug a truck wiring harness into a Van Tilt column?
Does anyone have the part number as well?
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-01-2005, 07:01 PM   #2
neonlarry
neonlarry's Avatar
http://67-72chevytrucks.com/vboard/s...threadid=75900
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-01-2005, 07:09 PM   #3
Super Duck
Chevy Nuttttt
Super Duck's Avatar
I might have one in the garage.
67' Chev swb step side
69' SS elky
03' Chev ext cab 4X4
hey who lernt me to spell
is there anything else?
Super Duck is offline   Reply With Quote
Old 06-01-2005, 10:07 PM   #4
John Fabris
TOTY 2006
Thanks Larry!!
What I want to do is remove the wires from the flat plug, and rewire them into the horseshoe plug. Even willing to by the adapter just to make sure I get the wires right, and then I would resell the adapter. (Still hoping that someone can post a close up picture of the adapter) Super Duck? If you find it, can you post a picture?
John Fabris
67 C10 SWB
Old 06-01-2005, 10:55 PM   #5
neonlarry
neonlarry's Avatar
I won't have my camera back till sat. I can take a pic then if you still need one.
Old 06-01-2005, 11:01 PM   #6
71swb4x4
71swb4x4's Avatar
Here you go.
I think the terminals are different on the van plug. I started mine, and then realized that they van terminal would not go into the horseshoe. I haven't started to look for the correct terminal. If worse comes to worse I will cut them off with about an inch of wire and solder the right terminals on. I am pretty sure the terminals should be pretty easy to find though.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-02-2005, 01:06 AM   #7
purple gas
I got the old 3 one the tree I was going to rob the other end off of,, any tips anyone?
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 06-02-2005, 01:31 AM   #8
Bob Moore
The ends are definitely different. The horseshoe ends are square shaped as shown above. The van ends are a flat blade style on the end of the turn signal wires and slotted recepticle on the adapter end.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 06-02-2005, 10:41 AM   #9
John Fabris
TOTY 2006
well, it looks liek the wiring is a one for one swap on the plugs, now off to the electronic store to see if they have the correct plugs (the square ones as Bob mentioned).
Thanks all!!! Really appreciate all of your help. It is hard nowadays to get to the junkyard for researcing this stuff now that I have a little guy to look after.
John Fabris
67 C10 SWB
