Old 04-13-2002, 11:34 PM   #1
RipMeyer
RipMeyer's Avatar
Post OIL Thick Or Thin? What Do You Use?
Is your oil thick or thin? What weight do you use? Multi viscosity? What are the determining factors to use thick or thin?
RipMeyer is offline   Reply With Quote
Old 04-13-2002, 11:44 PM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
I use Napa premium performace 10w-40 in everything I own. I suppose the determining factor for needed viscosity is the condition of your engine, if the cam bearings are worn, use heavier oil to boost oil pressure, if in good shape, use the 10-40, at least that's my theory.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-14-2002, 01:00 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I agree with his train of thought.
If the insides of your engine (or the # of miles) is unknown, run heavy stuff. I run 20/50 in both my drivers.
Thicker oil will 'cusion' the blow of sloppy bearings, and will also slow down blow by.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-14-2002, 03:28 AM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
Thick Valvoline MaxLife, 20w50, in my 120,000 mile 350.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-14-2002, 04:23 AM   #5
Southpa
Southpa's Avatar
Post
Thicker oil is also better for running in hotter climates. I'd go thinner in freezing conditions.
Southpa
1970 GMC 1500 Custom
Victoria, BC, Canada
http://communities.msn.com/Alsplac/shoebox.msnw
Original 350/TH350
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-14-2002, 04:41 AM   #6
Andy4639
Old member
Andy4639's Avatar
Cool
I live in the Southeast. SC and I use to run Castrol 20w-50 all the time until I found out that the heavy oil in the summer time could cost you power. I have been using Castrol oil 10w-30 ever since am pleased with it. I have a 93 sub. and 94 elderado and both of them recommend 10w-30, so I figured why not the 71 with 86 305 H.O. TPI. Sure makes changing the oil easier with only one oil to buy. Really think it has todo with climate,miles on motor mostly though it's just to the personal feelings of each.
Andy
71's Are for ever!!! or 67,68,69,70,72
www.geocities.com/chevy71tpi/main.html]
www.picturetrail.com/Andy4639]
[This message has been edited by Andy4639 (edited April 14, 2002).]
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-14-2002, 06:11 AM   #7
kurts72
Post
Everyone always has a thought on this topic and here's mine. I once bought a truck from an exectutive that had the oil changed every 2500 miles with 5w-30. At 100,000 miles it blew a head gasket and I removed the engine for rebuilding. Upon dissassembly, every item inside was scored and unusable including the rockerarms. I have never seen such worn components. Auto makers push for 5w30 to meet the fuel mileage requirements. 5w-30 will give a little more power because of less viscocity drag. It comes with a price in the end with worn components. I use 20w50 summer and 10w40 winter on all my vehicles. I have a new geo metro (wife drives 80 miles/day) and I run 20w50 Mobil 1 in it. Last time I had a new Metro in 1993 I ran 20w50 mobil 1 and I put on 150,000 on the 3 cylinder before someone rear ended me! Still ran super.
Kurt in Durand, IL
kurts72 is offline   Reply With Quote
Old 04-14-2002, 06:56 AM   #8
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
Post
I run 10w30 in the pick up and then what ever is recommended in the other vehicles. I had found on a 87 pontiac 6000 with a 2.5l l4 that if we ran 10w30 it would use a quart of oil in 3k mi but if we went back to 5w30 like was recommended it wouldn't use a drop. it had 218k on the speedo when we had to tear into it because the plastic crank sensor broke off in side the motor (didn't want it geting into the oil pump) and decided to put new bearings and rings because of the high mileage. we should have left the bearings alone, they had hardly any wear. it suprised the hell out of us. needless to say we will stay with castrol.
Also found on some of the new motors, if a person runs to thick of oil it will gum up the inside real bad. Have seen a few gernade because the pump couldn't move any oil. My theory is that the new motors run a little cooler and don't allow the oil to reach it's temp to do the cleaning part. haven't done much research on this though..
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 04-14-2002, 07:21 AM   #9
Andy4639
Old member
Andy4639's Avatar
Cool
Didn't mention got over 250,000 miles on the 71 86 TPI motor and 129,000 on the 93 sub. I drive the 71 everyday to work, and I travel between SC, and NC. Never had any kind of oil related problems with any of the cars. Oh 94 cadliac has 60,000 wifes car. What can I say. Like before I think it's what ever you want to use, doesn't matter. Just keep it changed.
Andy
Old 04-14-2002, 10:35 AM   #10
RipMeyer
RipMeyer's Avatar
Post
Ok, So what are you guys callin heavy? and is it multi viscosity?
Old 04-14-2002, 10:59 AM   #11
slam33
slam33's Avatar
Post
It's all going to depend on the condition of your main bearings. If there worn you would want to run a thicker oil to keep up pressure. I run 40wt. bucuse my bearing are a bit worn out. You don't want to go to thick or you may not get oil into the bearings or to thin becuse you won't get enough. My buddy snapped a billit BB crack in half becuse we built the motor for 50 racing and then he dumped 20/50 into it.
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 04-14-2002, 11:22 AM   #12
nucleus
nucleus's Avatar
Post
straight 20w in a tight engine
straight 30w in a loose engine
: 69 C20
: anything with tits or wheels is nothing but trouble ...
nucleus is offline   Reply With Quote
Old 04-14-2002, 01:21 PM   #13
bigjimzlll
bigjimzlll's Avatar
Post
where do you guys stand on synthetics? Im using castrol syntec...not just because john force promotes it...well..that is the reason..but is it any good?...and when u put together a new motor, do you break it in with a synthetic or a regular oil?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-14-2002, 06:55 PM   #14
slam33
slam33's Avatar
Post
Synth is good if you have a good motor. Never break it in on synth. Use a non detergent oil to break it in for the first 500 or so. then you can do a switch to synth
</A>
</A>
Old 04-14-2002, 07:06 PM   #15
gearhead dave
Post
ditto with southpa
1976 Crew Cab Dually (under construction)
1972 Suburban
1955 Pro Street Chevy
1985 S-10 Blazer (daily driver)
V W Sandrail
Located in Horn Lake, MS that's just 4 miles south of Memphis TN
www.classictruckshop.com/clubs/earlyburbs/members/gallery2/223/display.htm
Former engine builder for Racing Head Service
Performance Engines in Memphis TN. over 1,600 plus engines built by little ole me!!
GOD BLESS THE BRAVEST OF THE BRAVE...THE NEW YORK CITY FIRE FIGHTERS!!
gearhead dave is offline   Reply With Quote
Old 04-14-2002, 07:18 PM   #16
Desert Rat
Desert Rat's Avatar
Post
Straight 30wt in my motors.prefer Valvoline,but whatever is on sale sometimes,There all old and sloppy,oh one does get 50wt.,seems to go thru less oil.
Desert Rat is offline   Reply With Quote
Old 04-14-2002, 08:01 PM   #17
Reumster
L.E.D. Freak
Reumster's Avatar
Thumbs up
I stand by Castrol Synthetic blend, and or Full synthetic I run my engines hard. I just had it fully rebuilt ran Synthitic in it from the start, and have before almost ran the engine out of oil, and it never blew up, I don't care what anyone says Castrol synthtic works. And my uncle has put it in engines that smoke and it cuts engine smoking in half.
Thiner oil will give you more hp, but not if its cheap oil, because it'll wear your motor from accessive heat, and viscocity break down, but as long as its synthetic, or Castrol oil use 10-30 LOL Or Mobil if your rich! LOL
1972 2wd Blazer, 350/700R4/3:73 posi/NOS. Power is nothing without control!
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 04-14-2002, 11:16 PM   #18
lofly'a
lofly'a's Avatar
Post
castrol 20-50 in all my rides, it's always hot in louisiana
keep fly'in lo
66 gto ragtop 389/400
72 blazer (wuza4by)
68 swb fleet 350/700
98 tahoe 2dr (daily ride)
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 04-15-2002, 01:13 AM   #19
Project1970
14.1 @ 96MPH
Post
Synthetic rocks. Let's put it this way, after 80,000 miles each on Mobil1 full synthetic post-breakin, both the 1994 Z28 and 1997 Suburban keep the oil clean for quite some time (5000 mile oilchanges) into their changes. 10w30 in the Suburban, and 20w50 in the Camaro (LT1s don't build enough pressure with 10w30 synthetic!).
Whenever I get a new engine in my truck, it'll go synthetic too.
Old 04-15-2002, 02:08 AM   #20
nroden
nroden's Avatar
Post
I use Penzoil 10w30 (the original regular old oil) in my truck. Its just what I have always used.
Nick Rodenberg
Wellington, MO
http://nickrod.port5.com
You can click on "My 72 Chevy Truck"
I have a 72 Cheyenne 10 with a V8 350 and a TH-350 auto-tranny.
Ochre/White/Ochre
Runs well... working on body.
Plan to get painted weekend before memorial day weekend.
Planned to be done March 7 when I turned 16. Didn't happen. Chose to do better job and be behind schedule instead of 1/2 doing it and it looking like junk.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 04-15-2002, 07:30 PM   #21
dion
72 Cheyenne
dion's Avatar
Post
I have about 500 miles on my rebuilt, the oil has been changed twice with 20/50 by my Mechanic, should I switch to 10/30? I have been having a little problem with the pressure.
72 Cheyenne C20
Built 350/T350
AC/PS/PB/AT
Dana60 Leaf
Factory Saddle Tanks
San Diego, CA
Pics of My Truck
<A HREF="http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src=
ph&.last=1" TARGET=_blank>http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src=
ph&.last=1</A>
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
