Old 06-02-2005, 09:16 PM   #1
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
C20 Rear...
Do the C20 diffs have bigger axles that the C10's?? That may be what I have... I need a C10 rear 6 OR 5 lug. If the C20's have bigger axles, then that would explain why the 5 lug axles I have won't fit the diff that I currently have. Maybe I just confused everyone. Someone help! Later, Mark
FuelCellGuy is offline   Reply With Quote
Old 06-02-2005, 09:20 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i am not confused, i just dont have the answer for you
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 06-02-2005, 09:28 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The c/20 axle is nothing like the C/10 axles.
The 20 bolts to the hub and has splines on the oposite end.
a 10 axle has splines on the inner end, and a c clip on the same end to retain it.
Old 06-02-2005, 09:40 PM   #4
FuelCellGuy
FUEL CELL GURU
Was there a C10 "Heavy Half"?? or maybe a C10 Camper Special??
Old 06-02-2005, 10:25 PM   #5
kwmech
Not very likely.
Old 06-02-2005, 10:48 PM   #6
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
hey fuelcell guy i seen your wanting to buy 5 lug 12 bolt rearend in the parts board. I'm up in Oklahoma City and I might have one for you, but its at my buddies junkyard. I'll ask him tomorrow and see if he still has it and then i'll let you know.
WRMZ71 is offline   Reply With Quote
Old 06-02-2005, 11:03 PM   #7
Longhorn Man
Heavy half....that was later...late 70's early 80's.
Custom Camper...nothing but HD springs, shocks tires and a sway bar. That's it.
Old 06-02-2005, 11:43 PM   #8
67_C-30
I have a radical idea!
67_C-30's Avatar
Some 1/2 Tons came with 12 bolt GM rears and some had Dana 44's. That may be your problem. You may have Dana 44 axles and a 12 bolt rear, or vice versa. Look at you rear diff and count the bolts. If it has 12, it is a 12 bolt (you probably had that covered, huh? ) and if it has 10, it would be the Dana 44. I've never seen a Dana 44 with the coils springs in a 1/2 ton, but I'm not sure if they only came that way. The rear covers should look like either of the 2 below.
DANA 44
12 BOLT
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-03-2005, 07:27 AM   #9
FuelCellGuy
FUEL CELL GURU
67_C-30, I know for a fact that it is a regular 12 bolt. I could use the diff that I have but I would have to have the axles redrilled.
WRMZ71, yea, check into that if you will.
Thanks to all, Mark
Old 06-03-2005, 07:57 AM   #10
neonlarry
neonlarry's Avatar
How are the axles too big? Too long, Too big around, What?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-03-2005, 10:07 AM   #11
FuelCellGuy
FUEL CELL GURU
The ones in the housing now have a larger diameter spline than the one I bought that were supposed to be 71-72 axles. That's kinda where I am at.
Old 06-03-2005, 07:31 PM   #12
WRMZ71
WRMZ71's Avatar
fuelcellguy - My buddy knows he sold one of those 12 bolt 5 lugs but think he might have one left. I'll let you know as soon as I do.
